Old 07-04-2021, 06:46 AM   #1
harleycontracter
Default Identifying a 39 Tranny
Looking for a transmission. Was told 32-39 trans are similar. How do I tell it's a 39 and not an earlier one . From what I read case is the same ??
Thanks
harleycontracter is offline   Reply With Quote
Old 07-04-2021, 07:35 AM   #2
marko39
Default Re: Identifying a 39 Tranny
the serial number stamped on the case will identify the year made.
marko39 is offline   Reply With Quote
Old 07-04-2021, 08:00 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
You have to look inside, the serial number will show what years the case was originally used for, but the inside gears can still be most any year
Old 07-04-2021, 08:11 AM   #4
alanwoodieman
first you are looking for a 37 up case with the number 78-xxxx embossed in the rear of the case. second pull the top cover off and the 2/3 gear shift fork will measure 3" thus the trans will have the best synchronizer. third the serial number stamped into the top of the case will tell you the year
Old 07-04-2021, 09:22 AM   #5
FritzJr
FritzJr's Avatar
Some '39 transmissions used the older synchronizer and gears. You can not use only the serial number to determine if a '39 transmission has the later gears. The only sure way is to remove the top and look inside.
FritzJr is offline   Reply With Quote
Old 07-04-2021, 09:28 AM   #6
nickthebandit
Paul, check with Mark Van Pelt here on the Ford Barn. Get his book. He is the GURU of early Ford transmissions.
nickthebandit is offline   Reply With Quote
Old 07-04-2021, 01:14 PM   #7
harleycontracter
Yes I'm getting his book Was just recommended to me last week
Old 07-04-2021, 05:43 PM   #8
cas3
Take the shift tower off, and look at the syncro where the shift forks enter. If its in the middle, like a sliced bagel, its the old style, and if the fork goes in way off center its the 39 & up gearset.
Old 07-04-2021, 06:24 PM   #9
tubman
tubman's Avatar
Also, it should be mentioned here that if you have the "78" case, and he proper shift fork, later side shift gears will fit right in. You don't need '39 gears. It makes the parts situation a bit easier.
Old 07-04-2021, 08:21 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
So, as the tubman is saying, the gear set is the SAME from some 1939s thru 1948. Lots of '40-'48 transmissions still out there for parts. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-05-2021, 04:39 AM   #11
Clem Clement
Clem Clement's Avatar
where are you located?
Old 07-05-2021, 06:54 AM   #12
Mac VP
Mac VP's Avatar
This link will fill you in for most of the details:
http://www.vanpeltsales.com/FH_web/f...sID_3speed.htm
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.classictransmission.com
Mac VP is offline   Reply With Quote
