Old 02-12-2021, 07:04 PM   #1
harleycontracter
Default Dash Panel question
I can assume that the gauge panel I have with an oval speedo can be used on my 30/31 build ? Seems to work fine. I need a gas gauge. Are all the same ? What is the round hole I have in the center for? Dash light ? Thanks
harleycontracter is offline   Reply With Quote
Old 02-12-2021, 07:21 PM   #2
CarlG
CarlG's Avatar
Default Re: Dash Panel question
The gauge panel with the oval speedometer was only used up thru mid '30. Late '30 thru '31 end of production used the round speedometer.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-12-2021, 09:03 PM   #3
redmodelt
redmodelt's Avatar
He could have the early 1930 gas tank installed.
Old 02-12-2021, 10:24 PM   #4
harleycontracter
The holes line up perfect
Old 02-12-2021, 10:30 PM   #5
CWPASADENA
CWPASADENA's Avatar
All the gas gauges are interchangeable.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-13-2021, 07:44 AM   #6
marty in Ohio
marty in Ohio's Avatar
To answer Harley's final question, Yes, the round hole in the center is for the dash light.
Marty
marty in Ohio is offline   Reply With Quote
Old 02-13-2021, 08:33 AM   #7
harleycontracter
Thought so Thank you
Old 02-13-2021, 09:23 AM   #8
old31
Marty
x2.
old31 is offline   Reply With Quote
Old 02-14-2021, 11:03 AM   #9
brito36
All gas gauges are not the same. The later 1931 has a tang on the housing that keeps the gauge centered when you tighten the nut. There is also a small cut out in the tank itself that the tang fits into.
brito36 is offline   Reply With Quote
Old 02-14-2021, 04:40 PM   #10
Bob-A
Bob-A's Avatar
Cool Re: Dash Panel question
Just to throw in the pot..... I switched the instrument panel on my late '31 roadster. From the original rusty steel one to one of the uncommon "brass" ones. The original brushed nickle finish (I can't think of the proper name) was in nice shape on the brass one. However, the dish of the brass panel is not as deep as the steel one and can cause problems when using non-original
ignition switches.
Bob-A
Bob-A is offline   Reply With Quote
