10-16-2023, 03:29 PM | #1 |
Zenith internal passages
In scanning the catalogs for parts not included in the rebuild kit I saw the pkg of brass plugs for use after cleaning the internal passages. The red book says to clean them out if badly plugged, but there is no sketch of where they are and where they go. I have seen comments on this forum about the importance of cleaning them, so I might as well do so as long as the carb is under reconstruction. Is there a video or sketches that give details of these passages?
10-16-2023, 04:10 PM | #2 |
Re: Zenith internal passages
Russell,
Put down the carburetor and back away from your work bench. More Carburetors have been ruined by well intended novices attempting to remove those brass plugs. Your first step is to review Tom Endy's articles (MAFCA) on rebuilding & cleaning internal passages with a simple paper clip. |
10-16-2023, 04:21 PM | #3 |
X-2 on following Tom Endy’s articles !!! Can be found on several sites
10-16-2023, 04:24 PM | #4 | |
Tom Endy |
10-16-2023, 04:34 PM | #5 | |
www.whidbeymodelaclub.com |
10-16-2023, 04:40 PM | #6 | |
Tom Endy |
10-16-2023, 06:47 PM | #7 |
I used 0.031" stainless wire rather than a paper clip, you can get it on a roll from many industrial suppliers. I followed Tom Endy's directions but found you sometimes need to grind the end of the wire to remove the wedge formed when you cut the wire with a pair of dikes (tends to make the wire hang up a bit inside the passages).
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
10-16-2023, 09:25 PM | #8 |
Followup with carb cleaner from the pressurized container to check each circuit.
10-17-2023, 06:52 AM | #9 |
Never, I mean Never drill out the brass plugs on a Zenith Carburetor. Follow Tom Endys articles which are detailed and correct and blow air through the passages after and you will be in great shape.
10-17-2023, 07:01 AM | #10 |
UNCLE! I give up. I haven't read Tom's article yet, but I promise not to drill out any plugs
10-17-2023, 09:58 AM | #11 |
Unless your carburetor has been sitting at the bottom of the fish pond for years, blowing out the passage ways with pressurized carburetor cleaner will probably work. In fact, it is often not necessary to remove anything. Just split the carburetor and start squirting.
10-17-2023, 10:08 AM | #12 | |
This may help- https://www.youtube.com/watch?v=cR1ksgFaH90 Or maybe not. |
10-17-2023, 01:28 PM | #13 |
Volume 9 "How to Restore Your Model A" Article "Zenith Passageway Cleaning" by Tom Endy.
Not the same article as the above Santa Anita A link, but is the same author and the same information. Joe K
Shudda kept the horse. |
10-28-2023, 03:42 PM | #14 |
Update-- I finished rebuilding the Zenith according to the red book and Tom Endy's article. Attached the gas line, and she started right up. Two quick questions--the carb came with no GAV needle or choke driver. I installed the new ones, and the chrome indicator on the choke rod points to 4 o'clock when closed, compared to 11 o'clock with the previous Tillotson. Should I unscrew the GAV needle or needle housing to achieve a desired pointer setting, or just suck it up and stay aware of the setting that works? 2--the model A carbs don't have an idle adjustment screw. What is the preferred way to adjust the idle. With the GAV open a little (1/4 turn) and the throttle lever all the way up, there are not enough rpms to stay running. As I write this I recall needing to
shorten the throttle linkage when assembling the engine with the Tilly. Should I just restore some length until it sounds right? |
10-28-2023, 04:59 PM | #15 | |
www.whidbeymodelaclub.com Last edited by Gary WA; 12-30-2023 at 02:35 PM. |
10-29-2023, 08:40 AM | #16 |
The "Red book" (which you have) shows the idle adjusting screw on pages 1-59, 1-60 and 1-62.
10-29-2023, 09:35 AM | #17 |
