08-21-2018, 01:05 PM | #1 |
Labaron & Bonney don't know how to install their tops
Looking for help. I'm trying to install the top on a 33 Cabriolet and LB tech support haven't been very helpful. "We make top kits we don't install them" was the answer they gave.
Without instructions on how to put this together, im reaching out to the Barnners for help. Any pictures of completed 33 Cabriolet tops would help. Inside, outside, header, etc. In particular the side header assembly. Thanks |
08-21-2018, 01:21 PM | #2 |
Re: Labaron & Bonney don't know how to install their tops
They are going through huge changes at L/B.
These photo's are from my '34 cabriolet. I am not sure if '33 is the same. Last edited by 95476; 08-21-2018 at 01:34 PM. |
08-21-2018, 02:14 PM | #3 |
I found a video online when i did mine last year, used that as a tutorial
08-21-2018, 04:24 PM | #4 |
They sold you a top kit without instructions? That is very unlike the LeBaron -Bonney of the old days,.
08-21-2018, 04:34 PM | #5 |
My father installed a few LB tops on Ta and As, this was 30 years ago.
I don't recall instructions and do recall him cutting, sewing, stretching and cursing !! But he also made a couple from scratch...he was good at it. Taught himself by hanging around an upholstery shop after work. |
08-21-2018, 04:37 PM | #6 |
08-21-2018, 04:39 PM | #7 |
Thank you 95476 for the pics. Very helpful.
The instructions they sent are poor and incomplete. The kit included lift the dot fasteners but no mention of where they go. I got no instructions for rear window placement or top boot installation. Not sure where to put the snaps. I'm hoping to get more pictures. Every car I've seen and have pictures of seem to have a different top than the one they sent me. |
08-21-2018, 07:07 PM | #8 |
Someone on the barn here may have the original instructions that came with LB tops, and may be able to post them. One of the members posted a complete set of LB instructions with illustrations for installing a headliner in '40 coupe.
08-22-2018, 07:20 AM | #9 |
John I will text them to you. The ones I have are for a 34 roadster.
Assumption is the mother of all foul-ups. Last edited by stangblue; 08-22-2018 at 07:30 AM. |
08-22-2018, 11:30 AM | #10 |
I have installed several L B interior kits for both closed and open cars. In addition I have done 3 convertible tops. 2 were L B tops and 1 was for a 56 T bird. I bought some specialty tools and a good electric stapler.
I would say you have to have some innate ability to start with before you tackle a job as complex as an interior/top. I would imagine that any local shop should be able to handle your top installation. Show them the pictures of a finished top in terms of the little details, snaps etc. If a person doesn't feel comfortable L B has a list of certified shops that will install your kit. I just had a local guy do the seats for a 32 deluxe 2 door I'm working on. He charged me $400 to install the L B kit on the 2 front seats and the rear seat cushions. We used the original seat frames/springs etc. I will install the panel set and headliner etc. myself.
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 |
08-22-2018, 03:13 PM | #11 |
I had a local guy charge me 750.00 to put on L/B covers on a few years ago.
I watched him do much of the work. Never again. The last 2 I did myself including the headliners with encouragement from TJ. They came out fine. I should have been suspicious when I asked how much the job would be and he said he didn't know. Lucky for him I guess, he needed $750.00 to pay his rent that month. ' |
08-22-2018, 03:39 PM | #12 |
I have used L/B successfully for years. Their kits always contained full instructions. If, for some reason, this has changed, it will likely spell the end of the firm. For years they also installed tops, so I am quite surprised they said they no longer install. As for folding tops, I use a very good local auto trim place. Getting it right takes years of experience, and one wrong cut can turn a top into junk. Other interior trim should be easy.
08-22-2018, 04:24 PM | #13 |
This video is for a Model A, but should be helpful.
https://www.youtube.com/watch?v=JMqd8SoAAMQ |
08-25-2018, 07:53 AM | #14 |
I have the original 33-34 instructions (8 pages) and can send a copy. Send me a pm with your address and give me a few days to get the copies made. I can also send photos as you need them.
Al |
