Old 02-07-2013, 01:50 PM   #21
d.j. moordigian
d.j. moordigian's Avatar
Default Re: Where to buy, Wiring Harness and Glass
Originally Posted by Jeff/Illinois View Post
What's the best way to tell the difference between an original headlight terminal on a wiring harness vs. a reproduction? Anything really stand out? If I'm at a swap meet and pick up an 'old' wiring harness I want to know if it was from the 1960's or 70's, and is not worth using that terminal to get a new harness made off of it.
Also, how about the terminal can? What do you look for to find a good original??
Jeff,
Try this....I think you will like it....if not, go too search...OK.
.............................wire harness size.........................
d.j. moordigian is offline   Reply With Quote
Old 02-10-2013, 10:39 PM   #22
Mikeinnj
Mikeinnj's Avatar
Why tempered glass and not laminated? Curious....
Mikeinnj is offline   Reply With Quote
Old 02-11-2013, 06:47 AM   #23
Kevin in NJ
Laminated glass is designed to keep you in so it stays together. Tempered shatters in little pieces making it much easier for rescuers to help you in case of accident.
Probably not a problem with the A but I spent too many years taking people out of cars to know its value.
Kevin in NJ is offline   Reply With Quote
Old 02-11-2013, 08:41 AM   #24
Tom Wesenberg
Tom Wesenberg's Avatar
Also the tempered glass would look more original, and can't yellow or get air pockets.
Old 02-11-2013, 09:15 AM   #25
jim1932
jim1932's Avatar
I am putting in a harness form Tyree in my 32 and it is top quality. Also he takes the time to quiz you on your application to make sure all the correct connections are there. Looks just like the original including wire color etc. It also came with the diagrams you need to put it in.
jim1932 is offline   Reply With Quote
Old 02-11-2013, 09:36 AM   #26
wrndln
I agree with Kevin and Tom, tempered glass looks much better in the doors where you can see the top of the glass. Of course the windshield has to be laminated glass. I used tempered glass in my 28 special coupe and it worked out quite well. I used 3/16" thick glass like the original plate glass thickness Ford used for the quarter windows. Thickness is more important for the quarterwindows, as the rubber channel build up, plus the glass thickness can be too much if 1/4" glass is used.
Rusty Nelson
