Go Back   The Ford Barn > The Swap Meet > Wanted > Late V8
Old 05-15-2011, 07:20 AM   #1
GHerr1957
Default 272 4 barrel intake manifold
City: New Cumberland
State: Pa
I am restoring a 1957 F100 pickup. I would like to replace the stock 2 barrel intake with a 4 barrel intake manifold. This manifold must be in good condition. No cracks or stripped out bold holes please.
GHerr1957 is offline   Reply With Quote
Old 05-20-2011, 07:50 PM   #2
reman
Default Re: 272 4 barrel intake manifold
I have a question for you. What style 4V intake are you looking for? I don't think any 272's came with a 4V. All Y-block 4V for 55 and 56 were the square (teapot) style Holley carb. The 57 cars with 292 and 312 came with the modern style wide base intake that conventional Holleys and Autolites (later) fit. The 57 model 272 would not have come with 4V. Nor would have F-100 trucks. However, they will all interchange. Just different linkages. Is is a correct guess that the 57 and up type intake is what you want? Thanks
reman is offline   Reply With Quote
Old 05-21-2011, 06:28 AM   #3
raceron1120
raceron1120's Avatar
Early ones that take the small-base (like teapot carbs) is casting # ECZ-A, the later, wide base ones are ECZ-B <-that's probably what you're looking for?
If no other FBers have one, you might find one on ebay, they come up quite frequently over there.
Ron
raceron1120 is offline   Reply With Quote
Old 05-23-2011, 01:18 PM   #4
scicala
scicala's Avatar
I have an ECZ-A four barrel intake manifold from the 1956 model year. If your '57 272 has it's original heads (ECZ-G) then there would be a slight intake port mis-match. '57 heads and intakes had larger intake ports. The 1956 intake will still work, just has slightly smaller ports. It's available if you want it. The ECZ-B 1957 intake would be the most ideal. Sal (313) 805-0159.
