Old 03-17-2024, 08:12 PM   #1
Fordyguy
Fordyguy's Avatar
Default Headlight help
40 coupe passenger side headlight stopped working. It burns but really dim. I have checked the ground and it’s good. Checked wiring and switch and all seems fine. Tried switching headlight out and still the same. Any ideas?
Fordyguy is offline   Reply With Quote
Old 03-17-2024, 10:14 PM   #2
oldbugger
oldbugger's Avatar
Default Re: Headlight help
Try jumping a separate wire from a known good ground to the headlight
oldbugger is offline   Reply With Quote
Old 03-18-2024, 01:27 AM   #3
ford38v8
ford38v8's Avatar
Oldbugger gave a good answer, I'll just add that the crossover bullet connector may offer too much resistance.
Alan
Old 03-18-2024, 07:56 AM   #4
Fordyguy
Fordyguy's Avatar
I’ll give that a try…. Thanks
Old 03-18-2024, 08:59 AM   #5
pistonbroke
If it does the same on high beam and low beam it's a weak ground. If it's only one beam or the other it's bad feed somewhere in the line between the far end of the cross over and socket. Tim
Old 03-18-2024, 12:28 PM   #6
Fordyguy
Fordyguy's Avatar
It does do the same on high and low beam. I checked the ground on the headlight and was good and tight. Is there another ground I should check? It may be end of the week before I get a chance to check it.
Old 03-18-2024, 12:34 PM   #7
ford38v8
ford38v8's Avatar
Just being tight is not a good indicator. It could be corroded under the nut. Also, the headlight bucket may not be grounded properly to the fender, which itself may not be properly grounded to the frame. Too many iffy connections there. Run a dedicated ground wire directly to the frame.
Alan
Old 03-18-2024, 01:40 PM   #8
Kube
Kube's Avatar
I hide a wire within the loom that is directly soldered to the inside of each headlamp and taillamp bucket. The other end is hidden at the frame. I have found this makes a huge difference in brightness at each bucket.
Old 03-18-2024, 01:41 PM   #9
Fordyguy
Fordyguy's Avatar
Thank you!
