08-10-2012, 07:36 PM | #1 |
door hinge pins
hi guy
i need to take out the hinge pins on my 50 f1 pickup. dose anyone know of an easy way to take them out , or do i have to drill them out thanks steve |
08-10-2012, 08:06 PM | #2 |
Re: door hinge pins
The (C clamp type)Hinge removal tool that Bob Drake produces and is sold by most of the Venders discussed here works well as long as you use lubricant on the threads Mac's has it for $24.25 and is part # V46335Pull
Regards, Brian |
08-11-2012, 01:17 AM | #3 |
Re: door hinge pins
Hey Choice.......
I tried all kinds of things to get pins out, But Brian is right. Spend the $25 bucks and save yourself a lot of frustration. Use some penetrating oil while your waiting for c clamp to arrive. When tightening it down over the pin just go slow. When it pops......you'll know it ! It takes awhile but it works. Good luck Mike |
08-11-2012, 08:24 AM | #4 |
Re: door hinge pins
If you pins are badly rusted in place like mine were, all you'll do with this tool is bend the little pins they give to push the door pins out. In my case it was a waste of $25.00 . I ended up cutting the tops off and slowly driving them down and out.
Barry 50 F-1 |
08-11-2012, 09:19 AM | #5 |
Re: door hinge pins
Torchem Red Hot, lettem cool apply the penetrating oil and use the tool when it arrives, the heat turns the rust to powder....Damage to adjoining surfaces is likely if you try hammering them out without backup( a common mistake ) the tool works because all the pressure is focused on the pin,while hammering distrubutes the force everywhere
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford |
08-22-2012, 02:01 PM | #6 |
Re: door hinge pins
