Old 10-14-2015, 04:19 PM   #1
choiceph
Default timing change
hi guys
looking for some help
I have a 48 flathead. I want to advance the timing. the distributor is in the front between the water pumps . is the any way of turning the distributor
thanks
choiceph is offline   Reply With Quote
Old 10-14-2015, 05:20 PM   #2
Bill S
Default Re: timing change
Have you checked your manual?
Bill S is offline   Reply With Quote
Old 10-14-2015, 06:31 PM   #3
D. Jones
D. Jones's Avatar
48 was the year of two different styles/locations of distributors, car versus truck. I gather yours is the car/earlier style that sits low on the front of the block between the water pumps. There is a screw and an index marked plate under it on the right side as you look at the distributor. If you loosen the screw you can then push up, counter clockwise, on it to advance the timing or push it down to retard it. Doing that you're moving the points plate inside the distributor to change the timing. Quite simple.
D. Jones is offline   Reply With Quote
Old 10-14-2015, 06:32 PM   #4
Mike in AZ
Mike in AZ's Avatar
here's a link to MacVP's website showing timing setup on crab distributor.....which should be yours or yours with different cap and rotor...good luck...bookmark Mac's website, lots of good info there...Mike
http://www.vanpeltsales.com/FH_web/f...str-timing.htm
Mike in AZ is offline   Reply With Quote
Thread Tools
Display Modes
