09-28-2015, 09:22 AM | #1 |
Flickering headlights
'29 Model A is running fine but if you use the headlights and cowl lights, the lights flicker and the amp meter needle bounces back and forth. Car runs fine and will idle without a problem. Any ideas or quick fixes.
09-28-2015, 09:53 AM | #2 |
Re: Flickering headlights
Sand the cotacts at the bottom of the steering column.
09-28-2015, 09:56 AM | #3 |
I solved both of these problems by hard wiring thru the connector (using bullet connectors) and running a separate ground wire.
