03-16-2021, 08:29 PM | #1 |
AA truck brake switch question
Working on an AA truck in the shop. Replaced the wiring harness in the truck.
Everything is working now except the brake lights. Tester on the switch indicates the switch is not working, no continuity. There is a spring assembly that pulls on the back of the switch when the pedal is pushed. Can anyone advise how the spring holder on the opposite end of the spring is adjusted to allow the switch to work properly.???
Bob from Northport Northport, Michigan |
03-16-2021, 08:38 PM | #2 |
Re: AA truck brake switch question
You can loosen the two bolts holding it to the transmission tower and move the body of the switch. Perhaps that will be enough to allow it to activate. If not you will most likely need to pull the top cover off to see what is amiss inside.
Dave / Lincoln Nebraska |
03-16-2021, 08:54 PM | #3 |
Are you working on a 28-9 AA truck or a 30-31 AA truck?
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
03-16-2021, 09:02 PM | #4 |
There were two types used for 1930-31 trucks, none with a spring.
03-17-2021, 07:58 AM | #5 |
We are working on a 31 AA Truck. There is a spring attached to the brake switch, not a chain like in the photo. The other post referring to the tower is not this truck. Snyders shows a spring in their catalog. Just wondering about adjustment of the bracket on the brake rod.
03-17-2021, 11:11 AM | #6 |
03-17-2021, 11:14 AM | #7 |
Here is a picture from the parts book of AA-13511.
There are good pictures on pages E-18 and E-19 of the Judging Standards. |
03-17-2021, 06:22 PM | #8 |
This is what we have under the truck after we cleaned it up and installed a new switch. Just wondering about the adjustment of the new switch. Somewhere is the life of this truck someone changed the set up.
Bob from Northport Northport, Michigan Last edited by Bob from Northport; 01-24-2022 at 09:39 PM. |
