Old 03-01-2020, 06:16 PM   #1
twilder
twilder's Avatar
Default Clutch question
My clutch pedal goes down towards the floor approximately 1-2 inches before I shift. Is this correct? It shudders a little when I first pull out, but changes gears very smoothly. Only shudders at pull out no matter if I pull out in first or second gear. I'm just wondering if I need additional adjustment on the pedal. Thanks
twilder is offline   Reply With Quote
Old 03-01-2020, 07:21 PM   #2
larrys40
Default Re: Clutch question
You probably have a warped pressure plate/flywheel and or clutch fingers out of adjustment .
If it’s tolerqble I’d adjust the free play for 3/4 inch free travel or it it’s not tolerable a clutch job may be in order
Larry Shepard
larrys40 is offline   Reply With Quote
Old 03-01-2020, 07:47 PM   #3
Patrick L.
Patrick L.'s Avatar
Clutch free-play should be about 1-1.5". So your's is OK. Chatter is generally caused by pressure plate fingers [ other things can affect it also] not making contact equally. They can be checked thru the inspection cover, but, a little chatter isn't bad.
