10-05-2020, 11:46 AM | #1 |
1935 coupe-transmission removal
Need Guidance - We have a 1935 3 window that came with a later tranny with
matching original Ford column shift. Always worked great . Until now. The question is....If I slide the rear back , will there be room to get the tranny out the bottom past the original crossmember or does it have to come out thru the interior??? Thanks in Advance!! |
10-05-2020, 01:50 PM | #2 |
Re: 1935 coupe-transmission removal
Out thru the interior.
10-05-2020, 02:05 PM | #3 |
Starting with the '49 shoebox you could drop the transmission from beneath. Before that, they all come out from the inside of the vehicle.
10-05-2020, 05:07 PM | #4 |
