Old 09-21-2019, 07:43 AM   #1
mikek6741
Question Help, can anyone tell me what drum is this???
I have a 9inch Ford differential with no history and in need of rear brake drums. The specs on it are: 11 inch inside diameter, 2.25 in. brake surface, 5 lugs on 4.5 inch, total height of drum is 3.25 inches and an axle opening of 2 & 7/16inch. I have searched with two different parts houses and researched online to no avail. The rear of the differential has a dimple on either side and the total width from inside backing plate to plate is 51 +/-inch. Evidently a early and mid size Ford but that is all I have. A friend of mine said he had one that size for a 1957-8 Ford but it seems that those drums are unobtainable. Help ????
mikek6741 is offline   Reply With Quote
Old 09-21-2019, 12:05 PM   #2
tinman080
tinman080's Avatar
Default Re: Help, can anyone tell me what drum is this???
Might be 1959 Ford Police Special brake option- try these....https://opentrackerracing.com/product/11-x-2-25-drum-brake-for-small-bearing-ford-rear/
Just Passin' Thru.....Slowly!
tinman080 is offline   Reply With Quote
Old 09-21-2019, 01:03 PM   #3
KULTULZ
KULTULZ's Avatar
Post Re: Help, can anyone tell me what drum is this???
Does the axle assy still have the foundation brakes, backing plates, shoes?
Can you give shoe width?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 09-21-2019, 09:58 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
The '55/56 rear brake drums are 11" dia x 2-1/4" depth and 4-1/2" B.C., but I don't think they fit on a '57 thru 59 rear end for some reason.
Anybody else know???
Daves55Sedan is offline   Reply With Quote
Old 09-22-2019, 01:08 AM   #5
Alaska Jim
Alaska Jim's Avatar
Is the metal I.D. tad still bolted to the 3rd member drop out carrier? If so, it will have the model car, gear ratio, and other info on it. If you have it , post the #'s and letters here and I am sure that someone has the proper books to decode the info.
Alaska Jim is offline   Reply With Quote
Old 09-22-2019, 07:09 AM   #6
KULTULZ
KULTULZ's Avatar
Red face Re: Help, can anyone tell me what drum is this???
- The specs on it are: 11 inch inside diameter, 2.25 in. brake surface, 5 lugs on 4.5 inch, total height of drum is 3.25 inches and an axle opening of 2 & 7/16inch. -
Help ????
Yep. ready to make the call to the funny farm ...
I have called numerous times but they keep putting me on hold ...
- WHY IS IT ... -
Old 09-22-2019, 07:22 AM   #7
KULTULZ
KULTULZ's Avatar
Arrow Re: Help, can anyone tell me what drum is this???
OK...
I have taken my Geritol (w/ iron) and let me see if that brings me back into close Earth orbit ...
The brake size you are describing seems to be for a 63 FORD.
No guarantee, but is close.
P/N C3AZ 1126-B. C3AZ 1126-A may also work. GOOGLE both PN's.
Also FMS drums shown.
- WHY IS IT ... -
Old 09-22-2019, 12:18 PM   #8
rotorwrench
rotorwrench's Avatar
An old T-bird I used to have had some rather wide brake shoes but I don't remember how wide they were. It may have still been a Dana but I think it was a 9". Galaxie 500 and Mercury Monterey or Marauder maybe?
Old 09-22-2019, 05:29 PM   #9
Alaska Jim
Alaska Jim's Avatar
Do the drums have any "cooling fins" on them? I have a 9" Diff. from an early '70's LTD with brakes approx. the size you are describing. unfortunately, it is at my brothers shop 50 miles away, so I cannot verify the size of the shoes, but they are 11" or bigger
