12-11-2010, 07:45 PM | #1 |
small block Ford to early Ford transmission adapter
Does anybody make an adapter that allows an early Ford transmission to be bolted up to a 289-302 small block Ford?
Adapters exist for late 50's Fords, Chevys, Cadillacs and even Chrysler Hemis but I can't locate one for a 302 Ford (post 1965-6 bolt). Seems strange. |
12-11-2010, 08:19 PM | #2 |
Re: small block Ford to early Ford transmission adapter
Check this one out over on the H.A.M.B. The seller also posts here on the Barn.
Lee http://www.jalopyjournal.com/forum/s...d.php?t=535789
Salt Is Good... Mk 9:50 |
12-11-2010, 09:45 PM | #3 |
Speedway Motors
12-11-2010, 10:08 PM | #4 |
wilcap.com
12-11-2010, 10:43 PM | #5 |
2ndgeer,
They're not currently being produced so you'll have to hunt for one. I managed to score one for a 6 bolt motor at Moultrie a couple of years ago for $75 but haven't seen another before or since. Surprising that offy or wilcap or one of the other outfits hasn't seen the need (or market) for one. Rich |
12-12-2010, 08:29 AM | #6 |
i just sent him a message. there was not a poilet bushing addaptor with it when i got it. wilcap can probably make one |
12-12-2010, 06:30 PM | #7 |
There's one on the EV8 swap site NOW.....
Paul in CT |
12-12-2010, 07:26 PM | #8 |
Several of you guys didn't see where I said post-1965 6-bolt small block Ford. These engines are, of course, the overwhelming majority of SMB Fords, including all the 302's.
I know that a 5-bolt adapter exists (as in the sale item) but it is only useful for the early mid-60s 221, 260 and 289 versions. It may well be that no one has ever made one for the commonplace SBF? |
12-12-2010, 07:52 PM | #9 |
2ndgeer, i have an addaptor & i sent you a private message. don
12-12-2010, 08:36 PM | #10 | |
I mounted a '54 O.D. tranny to my '75 F-150 when the truck was new.
The trucks and the 351 equipped cars use cast-iron bells which have bosses cast into them where the early tranny boltpattern holes would be. I cut the face off an early tranny and used it as a guide for drilling the holes into the bell. I them tapped the holes. This was a long time ago but as I remember the only other things I had to do was find a front bearing retainer of the correct diameter to fit the the center hole in the bell and have a longer pilot bushing turned out of oillite bronze to reach out to the input shaft. I've since seen these long pilot bushings for sale at different places, including e-pay. It was pretty straight forward. Quote:
12-12-2010, 08:38 PM | #11 |
Well..........I was thinking stick, not auto! Sorry!
12-13-2010, 11:18 AM | #12 |
2ndgear,I know I'm a little slow,but are you looking for an adapter for a 5 bolt or a 6 bolt bell?You keep mentioning post 6 bolt but for a 302,and since all 302s are 6 bolt I'm confused.
Milt/Las Vegas |
08-20-2011, 06:22 PM | #13 |
I could really use a 5 bolt version if anyone has one.
08-20-2011, 07:46 PM | #14 |
There's one on the swap site now,w/picture.
Paul in CT |
08-20-2011, 08:03 PM | #15 |
2ndgeer, have you posted in "wanted" at HAMB? I needed the same adapter you're asking for and posted there. I got a reply (and eventual transaction) the next day. Good luck.
08-21-2011, 07:37 AM | #16 |
All of the ones posted in the swap meet are already sold.
05-09-2017, 08:55 PM | #17 |
I pick one up on e bay couple months ago for my 32 big truck that had a four cyl in it so I am trying to located a v8 bell housing (think I found one) My adapter came with directions and need to find out what they are from
Flywheel # is C50Z-6275-B Starter # C5TZ-11002-A Backing plate # C5AZ-7007B Any one have an idea what these are ford parts are from? Give me a shout [email protected] |
05-09-2017, 09:06 PM | #18 |
I see people say they did not make one. I picked one up on ebay couple months ago (hope it is correct) , it is new old stock and it was made by Trans-Dapt #690291 but I don't think they make them anymore. If you email me to my personal email I can try to find his name and phone number he says there is a company that does make them but not cheep. This guy seemed to know his stuff and he was very nice [email protected] I am not a mechanic so I am doing my best and going by what people tell me
05-10-2017, 10:03 PM | #19 |
05-11-2017, 07:59 AM | #20 |
I have one for the first generation 260 ci small block.
