01-18-2012, 08:46 PM | #1 |
'37 Lincoln Zephyr 3w Project
City:
Prince George
State:
B.C., Canada
Price:
$50K
1937 Lincoln Zephyr 3 Window Coupe
Rust free body stripped to bare metal All garnish mouldings, headlamp bezels, head lamp lenses, cowl vent, grill and stainless mouldings New fabricated frame with 4 link designed for air ride Dale Garry front suspension with new rack and pinion power steering New air bags 427 Ford side oiler, totally complete including dual quad manifold and air cleaner 4 speed top loader transmission Ford 9 inch rear differential 0 $50,000 At Joni's request, the price is reduced to $42,500 This was the project vehicle of a very good buddy of mine named Derek, who passed away a little over a year ago very unexpectedly. Derek was an amazingly talented man who would go to any length to help a buddy. His wife Joni, has reluctantly decided to part with it. As you can see it is a very nice original body with good parts to go with it. Joni would like to correspond with any interested parties via email to begin with. If you are sincerely interested she would be more than willing to answer any and all inquiries. If you are only somewhat interested; have only a portion of the asking price at your disposal; or have any other "deals" in mind, please don't waste her time. She's a fantastic person who wants to see her car go to someone worthy. Joni may be reached via email at: [email protected] The car is located in Prince George, B.C., Canada which is about 10 hours north of Vancouver, B.C. Do you have an idea of how you would ship or pickup this car from where it is, making the process as easy as possible for Joni?
You can touch the coupe, just don't fondle the chicken. Last edited by tinmann; 02-19-2012 at 03:14 PM. |
02-18-2012, 06:57 PM | #2 |
Re: '37 Lincoln Zephyr 3w Project
1964 427 Ford Center Oiler Block Casting id (C4AE 6015) date code 3K17. Block is 030 and can be fitted to stay there with custom pistons. Block has proper and intact cross-bolt mains and the mainline looks good. Proper steel 427 Crank, inspected and marked to run STD/STD. Manual 427 flywheel. Proper 427 harmonic balancer. Factory adjustable rocker-shaft assemblies. Factory 2x4 aluminum medium riser intake complete with carbs and factory 2x4 aluminum air cleaner assembly. Stock FE oil pan and oil pump. no set heads Other Ford stuff available: 1 68 or newer passenger side 428 CJ exhaust manifold. This manifold has had a crack repair done to it. It is repairable and serviceable. 2 68 390 GT cylinder heads (14 bolt style) CASTINGS ONLY. Casting #’s both C8AE-H 2 1970 429 Super Cobra-Jet exhaust manifolds. Some additional pics:
You can touch the coupe, just don't fondle the chicken. |
