Old 07-28-2020, 12:09 PM   #1
rfitzpatrick
Default U-Joint Lub
Is there a better way of lubing the throw-out bearing? My PicUp and I are getting older now days, and I'm having a hard time getting to it. Did install a transmission dip-stick which took care of that issue
Thanks
rfitzpatrick is offline   Reply With Quote
Old 07-28-2020, 12:39 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: U-Joint Lub
U-joint or throw out bearing?
Old 07-28-2020, 01:49 PM   #3
rfitzpatrick
The throw-out -- the one forward of the shift lever under a metal panel. I'm having to removed my thick floor mat. That u-joint is a bear too (for me
Old 07-28-2020, 01:56 PM   #4
Ruth
Most throw out bearings these days are sealed. How old is yours?
Ruth
Old 07-28-2020, 02:22 PM   #5
Patrick L.
Patrick L.'s Avatar
Most replacement release bearings today are sealed and can't be greased thru the collar fitting.
Older bearings can be greased thru the collar fitting.
A flexible hose could be fitted to the grease fitting to the side of the bell housing so the grease fitting could be accessed near the pedal shaft.
Old 07-28-2020, 04:12 PM   #6
rfitzpatrick
Ruth/Patrick
Sealed Bearing -- so that's what my problem is
Thank you
Old 07-28-2020, 04:17 PM   #7
Patrick L.
Patrick L.'s Avatar
That collar needs/should be greased every once in awhile, a pump or two will do.
