Old 06-01-2019, 03:05 PM   #1
thespoiler
thespoiler's Avatar
Default Bolts rear motor mount to clutch housing
I can not get the bolts holding rear motor mount to clutch housing out...ordered a thin wall socket which goes on the top bolt but socket wrench won't budge it....any secret here I don't know about
"Half the people you meet are below average".
thespoiler is offline   Reply With Quote
Old 06-01-2019, 04:12 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Bolts rear motor mount to clutch housing
I use one of those combination open end and socket type wrenches. Not much room to get a normal socket wrench in there.
Old 06-02-2019, 10:45 AM   #3
Jim Brierley
You can gain leverage by putting the box-end of a combination wrench on the bolt head and another box wrench onto the open end of the first wrench. A few cuss words sometimes helps too!
Jim Brierley is offline   Reply With Quote
Old 06-02-2019, 03:32 PM   #4
thespoiler
thespoiler's Avatar
Thanks...I can fit my thin-wall socket on the top bolt but there isn't enough space for the bottom bolts...These bolts have been there a long time...one place I read said use a 6" adjustable wrench on the bottom bolt....people have changed engines forever and Im surprised there isn't more written on this task...
Old 06-02-2019, 05:57 PM   #5
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
I took a box end wrench and ground the wall down just enough that I could fit it on the bottom bolt. Taking weight off the bolt may also help.
MickeyT is offline   Reply With Quote
Old 06-03-2019, 08:56 AM   #6
ryanheacox
ryanheacox's Avatar
Interesting. I was able to fit a ratchet and standard socket on mine.
ryanheacox is offline   Reply With Quote
Old 06-09-2019, 12:38 PM   #7
thespoiler
thespoiler's Avatar
I finally got top bots out with a thinwall socket, a breaker bar extend with a steel pipe. For the bottom bolt I had to cut the mounts in half with a sawzall and carbide blade....took a monster amount of torque to get them to move...now for rear float-a-mount...
Old 06-09-2019, 04:06 PM   #8
aermotor
I don't understand why if someone put them in, why can't they be taken out without destroying something?
John
aermotor is offline   Reply With Quote
