Old 03-10-2021, 02:38 AM   #1
Jembow
Jembow's Avatar
Default Factory fitted heater?
According to latest newsletter from Hagerty the 1929 Model A was the first car to offer the option of a factory fitted heater. Is that true?
Jembow is offline   Reply With Quote
Old 03-10-2021, 05:21 AM   #2
McMimmcs
McMimmcs's Avatar
Default Re: Factory fitted heater?
If it is it’s the first I’ve heard it and I have three 1929 Model A Fords and a 29 Chevrolet.
Old 03-10-2021, 07:05 AM   #3
Mike Peters
Mike Peters's Avatar
I vaguely remember some sort of vents that you could open and close under the floorboards of our 28 Tudor when I restored it back in the '80's. I took it all out because it was a hopeless mess. Didn't know if that was original or not.
Mike Peters is offline   Reply With Quote
Old 03-10-2021, 08:15 AM   #4
McMimmcs
McMimmcs's Avatar
Should it not be in the JS?
Old 03-10-2021, 08:17 AM   #5
Mike Peters
This was left under the rear floorboard of our Tudor. Heater? On the far side there is an opening to attach a hose or steel flex line? Maybe went to the muffler? It's just a vestige from long ago.
Old 03-10-2021, 08:25 AM   #6
Mike Peters
Yes. That's right. What I have on my car is NOT original. Speaking of the JS, on page 16-4 under Accessories, it says that Ford did sell a heater manifold, A-18455, that attached to the stock exhaust manifold. It required that a hole be cut (yikes!) in the fire wall.
Old 03-10-2021, 08:26 AM   #7
Kurt in NJ
Kurt in NJ's Avatar
The service bulletins show a tin manifold cover for heater but not factory installed it would have been dealer installed
