01-26-2017, 12:12 PM | #1 |
Packing the oil pump with Vasoline
Would someone tell me how to pack it? Do you fill the pump with oil and then pack the holes full of Vasoline or push Vasoline into all the holes when the pump is drained of oil, or what is the procedure?
Nothing wrong with it except for the name on the front. Alex |
01-26-2017, 12:28 PM | #2 |
Re: Packing the oil pump with Vasoline
I didn't pack mine with anything. I just rigged up a funnel to the oil pressure hole in the back and let 4 qts of oil slowly percolate into the block. Jack E/NJ
01-26-2017, 03:44 PM | #3 |
Pack the gears through the inlet before installing the pickup tube. I use Motors Assembly Lube but most anything will work to provide the sealing necessary for a quick action.
01-26-2017, 09:56 PM | #4 |
I agree, a good assy lube is much better than Vaseline.
Lubriplate no. 105 is a good one. |
01-27-2017, 12:26 AM | #5 |
Thanks.
01-27-2017, 09:07 AM | #6 |
01-27-2017, 09:11 AM | #7 | |
Your advice is spot on. I have a pressure bleeder, much like one used for bleeding brakes that attaches to the oil sending unit port. Once the valve is opened, it forces oil through the entire system. I have used this for decades on all sorts of engines.
