Old 10-15-2021, 08:47 AM   #1
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Canadian Intake Question
I picked up this intake @Hershey, and found the oil fill neck fracture m a buddy of mine. 59ab big truck cab over maybe?
Anyway, anyone know of a breather cap, stock or otherworldly de, I can use? We f anyone has one for sale or can sell me, send me a message. Thanks!
File Type: jpeg FB3DA20C-9C29-4980-A9C3-D18EF9030CAF.jpeg (97.3 KB, 140 views)
File Type: jpeg 2910545D-9CD4-492F-A61C-ED2B0AAD862C.jpeg (96.9 KB, 124 views)
File Type: jpeg BE872399-8320-4074-B567-F2F3B1663167.jpeg (62.0 KB, 117 views)
TomT/Williamsburg is offline   Reply With Quote
Old 10-15-2021, 09:15 AM   #2
Zeke3
Zeke3's Avatar
Default Re: Canadian Intake Question
I don't know what originally came on it, but it looks like a Corvair oil fill cap might work. No venting in the Corvair cap, it just seals the tube. Corvairs vented through the push rod tube o-rings, just kidding.
Zeke3 is offline   Reply With Quote
Old 10-15-2021, 09:21 AM   #3
TomT/Williamsburg
Thanks, Zeke - will check it out ….
Old 10-15-2021, 11:02 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
Tom .....I love those manifolds. As "handy" as you are at fabricating, here's a suggestion. Take one of these '63-'65 Corvette oil-fill tubes (available at all of the Vette outlets), along with this "twist-on" cap, cut that two-foot-long pipe down to some reasonable height, 'glue' them together....voila! You could even utilize the little HOSE connection for a PCV Valve, or not. The last picture shows what a Canadian friend of ours did with his similar manifold. He has mounted a PCV Valve below the plate. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-15-2021, 11:06 AM   #5
TomT/Williamsburg
There is actually what could almost be called a tapped in hole for a PCV valve in this manifold.
Thanks so much for the ideas!
Old 10-15-2021, 11:10 AM   #6
Zeke3
Zeke3's Avatar
Tom, here are some pictures of a Corvair oil fill and dimensions.
Old 10-15-2021, 11:10 AM   #7
V8COOPMAN
V8COOPMAN's Avatar
This is the ONLY picture that I have showing the stock CAP. DD
T5 W/TORQUE TUBE
Old 10-15-2021, 09:42 PM   #8
TomT/Williamsburg
Thanks so much, gents - I would like to use some version of the front fill pipe and incorporate a PCV valve. It all depends on the diameters of the Corvette and Corsair fill pipes vs the little over 1” OD of the stock pipe to see how much of a slice and dice it’s going to be ….
Old 10-16-2021, 12:19 AM   #9
Graeme / New Zealand
Graeme / New Zealand's Avatar
Plain twist on petrol cap for a v8 should fit. that's what I have on my oil filer tube which is on Canadian Aluminum manifold.
Gb
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 10-16-2021, 06:19 AM   #10
39fordtruck
I might have one
File Type: jpg A72DEC0E-A2A9-4306-9BCF-8FB26BD7F52C.jpg (63.9 KB, 84 views)
39fordtruck is offline   Reply With Quote
Old 10-16-2021, 06:21 AM   #11
39fordtruck
I’ve seen at least 2 different types.
Old 10-16-2021, 08:28 AM   #12
39fordtruck
Caps, one locks external and the other internal.
File Type: jpeg A35F02B5-9B03-406B-90AB-0C0CD0B353C6.jpeg (53.5 KB, 25 views)
File Type: jpeg A24B2BF0-62F5-4D6A-8501-EF95A99F89CD.jpeg (43.7 KB, 24 views)
Old 10-17-2021, 11:06 PM   #13
TomT/Williamsburg
I have the external locking cap style - first pic top left cap. If you would like to sell it please pm me. Thanks!
Old 10-18-2021, 08:04 PM   #14
Flathead
Flathead's Avatar
Obviously you know your Corvairs.
Flathead is offline   Reply With Quote
Old 10-19-2021, 11:35 AM   #15
Als48
Ha ha! I remember how they smelled. Couldn't keep the oil smell out of the ventilation system.
A H
Als48 is offline   Reply With Quote
Old 10-19-2021, 12:01 PM   #16
Tim Ayers
It's funny and just another example of how stubborn car companies are. All they had to do was copy VW's set up for the push rod tubes and the problem would be solved. Not sure why they felt they needed to reinvent the wheel.
Old 10-19-2021, 12:48 PM   #17
Zeke3
Zeke3's Avatar
I would argue that the problem was the material selected for the o-rings rather than the design of the tubes. Once Viton o-rings became available the problem was solved. The design was most likely driven by cost. The VW tubes and seals are much more robust.
Old 10-19-2021, 09:27 PM   #18
Flathead
Flathead's Avatar
I worked at a Chevy dealer when Corvairs still roamed the streets, don't get me started.
Old 10-20-2021, 08:46 AM   #19
Zeke3
Zeke3's Avatar
I hope all the cuts have healed from working with the sheet metal baffles.
I bet you have some great stories about them. I still have one, pretty rusty though.
Old 10-20-2021, 03:39 PM   #20
39fordtruck
I have to check and see if I have an extra one.
