09-14-2021, 09:25 PM | #1 |
Messed up D Nuts for header attachment
Guys this isn't my actual pic but the screws for the header broke and I had to drill a couple out . Well one got a broken bit and now the hole is offset. I ran a tap in it but it looks like crap. Functional but crappy. Has anyone ever drilled them out and welded plugs?
Or other ideas?? I can't get to the back. Maybe I could drill them out and fish a wire down to pull new ones and tack them on the front? |
09-14-2021, 10:43 PM | #2 |
Re: Messed up D Nuts for header attachment
Oversize?
09-15-2021, 05:15 AM | #3 |
I had that happen on cabriolet. Welded up and re-tapped. Not easy
I used a bottom tap as the area is not deep. I considered cutting out the front and feeding new d-nut and the patching. I could make that happen but didn’t…not out of the question. |
09-16-2021, 07:08 AM | #4 |
Here's mine...one side is ok the other is pretty bad. I may try to fix better after I sandblast. or should I say its good enough??
09-17-2021, 12:04 PM | #5 |
