Old 04-12-2012, 02:17 PM   #1
western77
western77's Avatar
Default Camshaft nut
What is the best way to hold the camshaft to put 100lbs torque on the nut that holds the timing gear?
western77 is offline   Reply With Quote
Old 04-12-2012, 03:06 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Camshaft nut
With 2 to 1 gear reduction, Marla held it from turning with the hand crank while Dave tightened it to 100 ft. lbs!!
( Now he's AFRAID to get her ticked off about ANYTHING!)
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-12-2012, 04:24 PM   #3
Lawrie
Lawrie's Avatar
I do it with the cam in the vice with soft jaws before I install the cam.
Lawrie
Lawrie is offline   Reply With Quote
Old 04-12-2012, 04:47 PM   #4
Patrick L.
Patrick L.'s Avatar
If its in the vehicle, just stick soft rag between the gears..
Old 04-12-2012, 06:56 PM   #5
Mikeinnj
Mikeinnj's Avatar
Put my new $420.00 Stipe cam in a soft jawed vise ? I don't think so.....and I do not think the rag between the gears would help he teeth on my new aluminum gear either....
Mikeinnj is offline   Reply With Quote
Old 04-12-2012, 07:17 PM   #6
BILL WILLIAMSON
Mike,
Recruit your honey with the hand crank.
GHOST
Old 04-12-2012, 08:33 PM   #7
ford1
if you knew how much pressure was put on the cam gear every time the engine fired you wouldnt worry about putting a rag between the cam and crank gear, and i dont thonk so Bill, i dont want my wife anywhere near me with a metal object in her hand, hows Pat? comforable i hope
ford1 is offline   Reply With Quote
Old 04-13-2012, 07:44 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
...I do not think the rag between the gears would help he teeth on my new aluminum gear either....
I've done it with the fiber gear and no damage to the gear teeth.
Old 04-13-2012, 08:22 AM   #9
western77
western77's Avatar
I talked to Bill Stipe and he refered me to a machine shop that does this kind of work. Ron said he installs the cam in the engine, holds the crank from turning and then torques the nut. It sounds alot like Bills method. Thanks all, JB
Old 04-13-2012, 11:46 AM   #10
Jim Brierley
I do as Lawrie does, in a vise with copper jaws. I use an impact wrench to tighten the nut. I grasp the cam by the front bearing. The cam is made of very good steel, don't worry about harming it.
Jim Brierley is offline   Reply With Quote
Old 04-13-2012, 12:26 PM   #11
George Miller
George Miller's Avatar
Make that three, I put the cam in a vise also. No rag between the teeth for me. If I change the fiber gear on the car,I take off the side cover and put a clamp across the gear.
George Miller is offline   Reply With Quote
