08-18-2011, 08:25 AM | #21 |
Re: Clutch Pedal Adjustment
bobpo: Explain to your wife it's 80 years old and does not have the emissions equip on it like the newer cars, and therefore is worth MORE money. Or it's possible you're running rich, have an exh leak or both.
Paul in CT |
08-18-2011, 08:49 AM | #22 |
Im just glad this thread solved 2 problems hahahha
_________________________________________ 1931 Ford Model A Tudor 1930 Ford Model A Deluxe Roadster 1930 Ford Original Rolling Chassis- Restoring |
08-18-2011, 03:43 PM | #23 | |
"P.S. How do you know all this stuff anyway.......????" I already sorta answered that, "God I love these cars. " I spent my mid to late teens in a constant arguement with a freebie 1931 A. Example: When you lay on the fender with the points wire in your hand making the coil spark for about a week it finally sinks in, "Wow, if I can do this and get spark why can't the points? Duhhhhhhhhh, because they are not grounded! Wow." Just another lesson I will never forget. |
08-18-2011, 06:54 PM | #24 |
Holy smoke...'for about a week' ....You got a lot of el cajones!!
08-18-2011, 07:18 PM | #25 |
11-10-2016, 02:20 AM | #26 | |
11-10-2016, 10:54 PM | #27 | |
Also despite the light clutch in in my 1928 Tudor, even with size eleven shoes, I cannot easily depress the clutch with my heel on the floor. |
11-12-2016, 11:03 PM | #28 |
should the 1" clearance be also for the V8 clutch and pressure plate which has 3 fingers?
