02-05-2022, 01:25 AM | #1 |
stripping running boards
oh boy started stripping vulcanised running boards any cheats or just heatgun /scraper and elbow grease
02-05-2022, 01:37 AM | #2 | |
Re: stripping running boards
No cheating here. The end result must be perfectly smooth boards, no chips, gouges, or dents. Imperfections will show through the new rubber.
Alan |
02-05-2022, 01:45 AM | #3 |
bingo
02-05-2022, 06:17 AM | #4 |
I removed the vulcanized rubber from my '40 Fordor running boards last month. I used an old 1.5 inch wood chisel to chip off the rubber. It was a bear of a job, as you’re finding out. Then a long time getting it all smooth. Putting the new rubber down took time and patience but it wasn’t difficult. Good luck on your boards.
02-05-2022, 10:22 AM | #5 |
The rubber on my '35 sedan was so hard; I wound up using an air chisel with a 1" tip. Made a mess, but was pretty quick, and really no damage to the board that wasn't already there.
02-05-2022, 11:13 AM | #6 |
02-05-2022, 11:17 AM | #7 |
I haven't ever tried it on vulcanized rubber but have on silicon based rubber and that is plain old mineral spirits. It is the only thing that would soften thick RTV coatings enough that I could easily scrape the stuff off. It wouldn't hurt to try it.
02-05-2022, 02:45 PM | #8 |
I've stripped the rubber off of seven pairs of boards in my past. I'd used an oxyacetylene torch on the back while scraping the front with a very stiff (1" wide) putty knife.
It takes but a minute or two to get a good rhythm going. It is not necessary to get the board very hot.
