Old 05-13-2022, 05:55 PM   #1
ShaneF205
Default white walls
Can I get some advice as to what to clean my white walls with? Mine are brown around the outer edges on two of the tires. They seem to do this even when I don't drive the truck.
And is there a white paint or polish I can use to make them look whiter? If that's even a word....
Thanks for your help...
Shane
ShaneF205 is offline   Reply With Quote
Old 05-13-2022, 06:09 PM   #2
aussie merc
aussie merc's Avatar
Default Re: white walls
soap and soft scrub brush there are products out there that they say work but havent seen actual tire white for years and brush on tyre black is getting hard to find its all gone to spray cans that just hold dirt
aussie merc is offline   Reply With Quote
Old 05-13-2022, 06:40 PM   #3
Kpar
Kpar's Avatar
I use "Simply Green" works great.
Kpar
Kpar is offline   Reply With Quote
Old 05-13-2022, 07:31 PM   #4
51504bat
51504bat's Avatar
Mr. Clean Magic Eraser
51504bat is online now   Reply With Quote
Old 05-13-2022, 08:04 PM   #5
47Monarch
47Monarch's Avatar
Simple green and a soft scrub brush
47Monarch is offline   Reply With Quote
Old 05-13-2022, 08:28 PM   #6
paul2748
paul2748's Avatar
Had the problem with my wide whites. Used Super Clean (purple cleaner) and a bristle brush and cleaned it away. Also try Simple Green, 409, Fantastic
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-13-2022, 08:34 PM   #7
ShaneF205
Thank you all. You've been a big help.
Old 05-13-2022, 08:53 PM   #8
ssffnomad
ssffnomad's Avatar
Soft Brush is a must. I use a large finger nail brush.
Stretch
ssffnomad is online now   Reply With Quote
Old 05-14-2022, 10:14 PM   #9
fordor41
fordor41's Avatar
brillo pads that have soap in them
fordor41 is offline   Reply With Quote
Old 05-15-2022, 03:51 AM   #10
aussie merc
yeh brillo pads work but their a bit harsh for every wash i would use with due care and caution
Old 05-15-2022, 05:38 AM   #11
deuce lover
deuce lover's Avatar
Have had WW's off and on since 1962 .What fordor41 says IMO.
Old 05-15-2022, 06:08 AM   #12
Jacques1960
Jacques1960's Avatar
Bleche Wite is a reliable product for whitewall cleaning
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 05-15-2022, 06:12 AM   #13
deuce lover
I tried all that other stuff and nothing works like Brillo soap pads. That other stuff will not remove a scuff.
Old 05-15-2022, 06:18 AM   #14
corvette8n
corvette8n's Avatar
Used to be Westleys bleach-rite but I guess someone else bought it, heard it doesn’t work like the old stuff. NAPA and Amazon carry it.
File Type: jpg F46AE8A9-B7FB-457B-97E1-9ECF5CE90209.jpg (26.3 KB, 19 views)
Old 05-15-2022, 12:07 PM   #15
Cool Hand Lurker
Cool Hand Lurker's Avatar
I have a good friend who owns a tire shop and I asked him if he sprayed something on my new tires because in a few months they got this brown haze on the surface. I suspected silicone but he said there was a period when a new rubber formula hit the market and tires turned brown. That is supposed to be corrected and off the market by now. But my tires still turn brown. So I just drive through some mud on the way to a show.
Cool Hand Lurker is offline   Reply With Quote
Old 05-19-2022, 06:21 PM   #16
bobsmanstuff
bobsmanstuff's Avatar
simple green or superior 1000.
bobsmanstuff is offline   Reply With Quote
Old 05-19-2022, 06:42 PM   #17
Randy in ca
Randy in ca's Avatar
Are you referring to steel wool pads? Seems pretty harsh. Does Brillo make something else?
Randy in ca is offline   Reply With Quote
Old 05-19-2022, 06:55 PM   #18
Krylon32
Another vote for Simple Green. That's what the guys over at Diamond Back recommended. I've cleaned the WW's on my 40 with it several times and it's worked good.
Krylon32 is offline   Reply With Quote
Old 05-20-2022, 12:22 AM   #19
deuce lover
Yes Brillo steel wool soap pads.Works every time.Don't exist here in France.Had some mailed in.A friend here with WW on his 53 Ford custom could not get them clean with "conventional" over the counter stuff. The brillo pads worked. I have scuffed a WW on my '36 Ford a few yrs back and the Brillo's were the only thing that worked . Harsh -not really IMO but it works.Remember its just a tire . Had the old Denman WW (bought them as seconds from Lucas in Long Beach,CA)on a '34 Vic I restored in 1970.They turned light brown , Brillo worked although the kept turning brown every 6 months.
Old 05-20-2022, 10:53 AM   #20
blucar
blucar's Avatar
I have been using BRILLO/SOS, fine steel-wool soap pads, to clean white-side wall tires since the early '50's.. The soap pads work great to clean road grime, curb scuffs etc., from WW's with no apparent harm to the tires.
I always wet the pad and use plenty of water on the tire to rinse the tire off.
BRILLO/SOS pads are also great to clean stainless steel, chrome trim. The steel-wool in the pad is probably finer than 000 steel-wool.
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
