08-30-2017, 03:15 AM | #1 |
Differentiel gear ratio change?
Hello everybody
Some guy told me that the gearbox ratio from a 28-29 model A rear end is different then a 30-31? Is this true? Best regards Philips M. |
08-30-2017, 04:06 AM | #2 |
Re: Differentiel gear ratio change?
My 1928 has the stock 3.70 to 1 ratio, and most all of the 1929 -1931 cars would have the stock 3.78 to 1 ratio.
08-30-2017, 07:31 AM | #3 |
When I was young people said that the roadsters and phaetons had the 354 rear in them. Is that true? Jack
08-30-2017, 11:44 AM | #4 |
08-30-2017, 01:53 PM | #5 |
The the 3.70 is a very slightly higher gear than the 3.78 so you will go very (and I mean very) slightly quicker with the 3.78 ratio.
John in dark rainy Suffolk County England . |
08-30-2017, 03:12 PM | #6 |
08-30-2017, 04:27 PM | #7 | |
I have a rear end with a 4.11 R&P in it. Someday if I get to build my hill climb car that's going in it.
Blackwall Panthers Nor Cal chapter |
08-30-2017, 06:22 PM | #8 | |
Vince Falter's site says that 3.54's were Post 1934 and available in the AfterMarket for A and B Models. Not sure what year they came out in Aftermarket. Read about it here: http://www.fordgarage.com/pages/rearaxleratios.htm Last edited by Benson; 08-30-2017 at 06:58 PM. |
08-30-2017, 07:06 PM | #9 | |
Right or wrong, this gear set works well in a light roadster...it does seem to go nicely. Last edited by hardtimes; 08-30-2017 at 07:08 PM. Reason: ..... |
08-30-2017, 08:43 PM | #10 |
I have a 29 Special Coupe that pinion nuts came loose. When I took it apart I found it had 4.11 gear set in it. I ordered a 3.54 gear set with new bearings and seals and never looked back, great cruise speed at 50 to 55 mph and I have been 65 mph with out straining the engine.
08-30-2017, 09:55 PM | #11 |
You NEVER know what "someone" put in these OLD cars! Some people even have "UPGRADED" body parts & pieces!---I have 1999 Stents & 2001 Titanium Screws & a rod from 1981!
Bill Heinz
08-30-2017, 10:15 PM | #12 |
To make a car feel more peppy/sporty, you would install a LOWER gear ratio, not a higher one.
All steel from pedal to wheel |
08-30-2017, 11:17 PM | #13 |
I don't know this to be true but have always heard that the 29 Model A was the fastest of the 4 years of production.
08-31-2017, 10:48 AM | #14 | |
I've also heard that the '32 V-8 was the FASTEST V-8, because of some SNEAKY Cam they used, for 1 year only???--I "think" I heard it was a STEEL cam???? Bill Racer
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 08-31-2017 at 12:05 PM. |
