Old 06-20-2016, 01:54 PM   #1
JOHN CT
JOHN CT's Avatar
Default Is this a crack ?
I opened the hood today to check the oil today,and I never noticed a crack behind the oiler filler tube. Or is it a scratch in the paint it's not leaking anything at this time.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 06-20-2016, 02:00 PM   #2
DJ S
DJ S's Avatar
Default Re: Is this a crack ?
Hard to say just through a picture.
DJ S is offline   Reply With Quote
Old 06-20-2016, 02:06 PM   #3
Terry, NJ
Terry, NJ's Avatar
Probably a scratch. Cracks usually have water/rust stains from the leaking when they get hot and leak. Is your water level going down? Does it run hot? Next time you have it out for ride throw open the hood and see. However! The left side of the block, just under the head is one of the spots to look for cracks, but I think they're usually horizontal, not vertical.
Terry
Old 06-20-2016, 02:07 PM   #4
bogdonj
bogdonj's Avatar
I would try and clean the paint off that area to have a better look.
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 06-20-2016, 02:12 PM   #5
1wonton
Stick a magnet next to the area and sprinkle some iron filings over the spot, if it's a crack the filings will line up showing the damage.
1wonton is offline   Reply With Quote
Old 06-20-2016, 03:19 PM   #6
JOHN CT
JOHN CT's Avatar
I just went for a ride got everything up to temperature, and it looks the same . Nothing leaking. I rubbed my finger over it and it seems to be fine . I just worry about things to much sometimes
31 Tudor
66 Bonneville
Old 06-20-2016, 03:30 PM   #7
coupe1942
coupe1942's Avatar
Duct tape fixes everything............. :-)
coupe1942 is offline   Reply With Quote
Old 06-20-2016, 03:36 PM   #8
wrndln
Usually block cracks run lengthwise, not vertical like this one might be. Like some above posted, wire brush the area and see what is beneath the area that might be a crack.
Rusty Nelson
Old 06-20-2016, 05:08 PM   #9
Indiana A. Lover
Send a message via Yahoo to Indiana A. Lover
If it aint leaking leave it alone
Indiana A. Lover is offline   Reply With Quote
Old 06-20-2016, 08:32 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
If you always use antifreeze I'd guess you have a scratch in the paint.
If you are a water only user, I'd not only worry about a crack, but also the circulating rust.
I also see horizontal cracks on blocks, and don't ever recall a vertical crack.
