Old 04-10-2017, 04:27 PM   #1
adileo
adileo's Avatar
Default 52 F1 leaf spring
Hi folks
I've accomplished many first time projects (with a lot of good advise here) since purchasing my 52 f1. I'm now looking to another.
LMC sells a 3" lowering front leaf spring (sorry 4 sideways pic attached).
Since my truck front spring is shot. I'm thinking of this as a replacement.
The questions:
- how hard is it to replace? What to watch out for...
- is the spring under tension when truck is jacked up?
- can someone provide a step by step procedure?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 04-10-2017, 04:48 PM   #2
JSeery
JSeery's Avatar
Default Re: 52 F1 leaf spring
Should be a fairly easy mod. This springs are not under tension if it is supported properly.
Old 04-10-2017, 05:01 PM   #3
adileo
adileo's Avatar
Hey Jerry
Can you elaborate? Properly supported, meaning have a jack under it to eliminate tension?
Thanks
Andy
1952 F1
Old 04-10-2017, 05:06 PM   #4
MMB
Not that you asked, but you may also want to consider a dropped axle with stock multileaf springs. If the ride is too stiff you could remove a leaf or two to suit your tastes. Not hard to accomplish either way you decide.
MMB is offline   Reply With Quote
Old 04-10-2017, 05:30 PM   #5
JSeery
JSeery's Avatar
Originally Posted by adileo View Post
Hey Jerry
Yes, LOL. The springs are only shackled at one end. If you support the spring the shackle can be removed and then the fixed end. Take a look at it and you should be able to see how it goes together (and comes apart).
From the manual:
Raise the truck frame until the weight is off the springs but so the wheels still remain on the floor. Remove the nuts from the lower shackle bolt and drive the bolts from the shackle and bracket. Remove the nuts from the two U-bolts which secure the spring to the axle.
Old 04-10-2017, 05:36 PM   #6
adileo
adileo's Avatar
Thanks, better to safe and understand than sorry
Your the Best!!
Thanks
Andy
1952 F1
Old 04-10-2017, 05:52 PM   #7
JSeery
JSeery's Avatar
Here are a couple of typical type photos (they are of earlier years, but similar setup).
Old 04-10-2017, 05:52 PM   #8
Ken Crans
Ken Crans's Avatar
Andy,You can do it one of 2 ways as mentioned above by Jerry,or by putting jack stands under the front part of frame to let everything hang.. then knock out 4 pins and drop the axle and springs together then you can get out on floor to disassemble alot easier that way the you can also evaluate all the other components and go from there.
Ken Crans is offline   Reply With Quote
Old 04-10-2017, 05:58 PM   #9
adileo
adileo's Avatar
Thanks Ken, I think, I'll stick with Jerry's advise. I have a four post lift, it should make it somewhat easier
Thanks
Andy
1952 F1
Old 04-11-2017, 07:57 AM   #10
GreenMonster48
GreenMonster48's Avatar
I just did this over the weekend on my '48.
LMC is just re-selling Posie's Dual Flex Springs. You can get them cheaper through SPeedway motors.
I bought the shackle kit from Dennis Carpenter to complete the job.
http://www.posiesrodsandcustoms.com/...-installation/
this link tells you all you need to know.
It lowered my truck about 1 1/2", my old springs were pretty tired. Probably a full 3" from factory height. I like the look, but the ride is so. much. better.!
GreenMonster48 is offline   Reply With Quote
Old 04-11-2017, 09:01 AM   #11
adileo
adileo's Avatar
Excellent and your right Speedway much cheaper and free shipping.
Another reason this site is so great!!
Thanks
Andy
1952 F1
Old 04-11-2017, 10:37 AM   #12
GreenMonster48
IMG_2621.jpg here's my truck with the springs. Was 17.5" inches from the ground to the top of the front bumper, now it's just under 16"
Old 04-11-2017, 10:47 AM   #13
adileo
adileo's Avatar
Great looking truck with a perfect stance.
Thanks
Andy
1952 F1
