12-17-2020, 09:48 AM | #1 |
Model BB bellhousing
Since I have never run across run before,Is this what I think it is? Big truck bellhousing?
12-17-2020, 10:00 AM | #2 |
Re: Model BB bellhousing
Yes
The one you want when putting a 5 speed behind an A or B motor. You may also need an adapter plate depending on the trans. They were available a while back.
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 |
12-17-2020, 05:28 PM | #3 |
The BB clutch housing will not bolt to an A flywheel cover so if you are putting a 5 speed behind a Model A you need the AA clutch housing. The AA has a socket for the wishbone, the BB's does not because the 32 wishbone connected to the K-member. Both of the housings look the same with respect to the transmission bolt pattern.
12-17-2020, 06:06 PM | #4 |
I am not familiar with that bellhousing, but it is not the hogshead used with V8 flatheads as the basis for an adapter to a later transmission.
12-17-2020, 07:23 PM | #5 |
The pictured bell housing is for a 4 cylinder.
12-18-2020, 12:19 AM | #6 |
12-18-2020, 01:14 AM | #7 |
Thanks for all the replies.Now to see if someone elsewhere can use it. I will put it in the Swap Meet section.No one here in France has a clue.
