Old 12-10-2013, 10:28 AM   #1
phartman
phartman's Avatar
Default Firing Order: Y-Block Police Interceptor Camshaft
My engine builder tells me that the Police Interceptor camshaft had a different timing sequence than the stock cam. True? Anybody know?
I acquired an Elgin grind that was represented as their version of the Police Interceptor, but my builder tells me that once he installed it in my 272 motor, this cam has the same timing order as stock, and he was surprised.
Can anybody shed light on what he's talking about? I had never heard of the firing order changing from camshaft grind to grind. Thanks.
Pete
Richmond, VA
phartman is offline   Reply With Quote
Old 12-10-2013, 10:54 AM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Firing Order: Y-Block Police Interceptor Camshaft
I think your engine builder has been smoking Fan Belts. There has never been a change in Y-Block firing order unless someone ground a custom cam for some reason that eludes me way??
Unless your builder is referring to VALVE TIMING as opposed to IGNITION TIMING in which case an Intercetor cam should be different than stock. I don't know the specs but for example the intakes opening sooner, more duration, etc.
Old 12-10-2013, 10:54 AM   #3
Oldmics
Pete
You mention firing order,timing sequence and timing order.
These are all different cycles and events connected to a cams function.
If you are just curious about the firing order,it would be the same as stock in a Police Interceptor engine.
Oldmics
Oldmics is offline   Reply With Quote
Old 12-10-2013, 10:57 AM   #4
scicala
scicala's Avatar
The only firing order change I know of in Ford V8's is between the 289/302 and the 351 Windsor. The 351 Windsor had a unique firing order.
Old 12-10-2013, 11:22 AM   #5
phartman
phartman's Avatar
Originally Posted by Oldmics View Post
Pete
Oldmics
He was referring to firing order.
Old 12-10-2013, 09:52 PM   #6
Herman Munster
Herman Munster's Avatar
Grab all your parts from him and run fast and as far away as you can from him.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Herman Munster is offline   Reply With Quote
Old 12-11-2013, 10:03 AM   #7
Ole Don
Ole Don's Avatar
I think Herman Munster has the best advice! I would never mention anything like that in passing. I would open a book to find out the answer.
Ole Don is offline   Reply With Quote
Old 12-11-2013, 10:19 AM   #8
LOWRIDER
LOWRIDER's Avatar
Maybe he was thinking he had a scrub motor cam with the 7-4 firing order change? I agree with Herman Munster & Old Don.
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 12-11-2013, 11:16 AM   #9
Hot Rod Reverend
Hot Rod Reverend's Avatar
Y Block firing order has never been changed... my two cents
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 12-12-2013, 08:49 AM   #10
TedEaton
TedEaton's Avatar
The scrub engines with the 7-4 swap makes it the same firing order as the YBlock and the Flat head V8. Depending upon the year you're looking at for the camshaft timing specs, then the 1957 YBlock 2V & 4V specs should be in the ball park for the Police Interceptor specs. See if these values for the '57 camshaft helps. IO-18 BTDC, IC-58 ABDC, EO-66 BBDC, EC-10 ATDC.
Ted Eaton.
TedEaton is offline   Reply With Quote
