Old 12-04-2020, 09:30 AM   #1
Automotive Stud
Automotive Stud's Avatar
Default Emergency brake setup
I'm installing a new rear cable on my '40. Where the cable grabs the lever in the rear drum, there is a spring on the cable and a small metal clip to retain tension on the cable. I looked through all of my motor manuals but I haven't found anything on where the clip should be placed on the spring. How do I determine where it should go and how much tension should be on that return spring? Also, should the brake adjustment be set prior to that, then remove the drum to install and set the cable I assume?
Automotive Stud is offline   Reply With Quote
Old 12-04-2020, 09:43 AM   #2
TJ
TJ's Avatar
Default Re: Emergency brake setup
The clip goes between the spring and the steel tube on the backing plate. It keeps the spring from going inside the tube. You make the adjustment to the brake after all is put back together.
Old 12-04-2020, 10:07 AM   #3
rich b
rich b's Avatar
We found the springs on the repop cables are too long/too stiff.
We have been inserting the clip between the coils which leaves some of the spring inside the tube and effectively shortens the working length of the spring.
Old 12-04-2020, 10:15 AM   #4
Automotive Stud
Right, but is there a set amount to put into the tube? Every one I've had apart already had some spring in the tube, so the clip goes in the middle of the spring somewhere. Maybe I'm overthinking this and it's not that critical. The last one I did I had to move the clip because I wasn't happy with how it was working. Maybe it's just trial and error.
Old 12-04-2020, 11:36 AM   #5
Tim Ayers
Timely, I have the same question as Automotive Stud does. I can't seem to figure out the spring clip thing.
If possible, can someone post a pict of how it supposed to look? I would greatly appreciate it.
Also, are the cable all the same length or are there different lengths for different years?
Old 12-04-2020, 11:58 AM   #6
19Fordy
19Fordy's Avatar
Here is how my 40 Ford E-Brake "clips" are installed. The little "spring clip" is in front of the tube.
I installed this with the E-brake released and cable "loose" - not under tension.
If you happen to lose one of those clips, you can make one out of the old style flat steel banding used on packing crates. It's "springy" but you can drill it and cut it to shape with aviation snips.
Old 12-04-2020, 12:18 PM   #7
Tim Ayers
Originally Posted by 19Fordy View Post
Here is how my 40 Ford E-Brake "clips" are installed. The little clip is in front of the tube.
I installed this with the E-brake released.
Perfect. Just what I needed to see. Thank you!
Old 12-04-2020, 12:59 PM   #8
Kube
Kube's Avatar
Tim, Please pay special attention to the springs. As has been rightfully advised, the repop's have springs that are way too long. When installed they should be of a (proper) length so the shoe is not "pushed".
There are different lengths for different years. Carpenter has a good cable with the rubber seals installed. Still, like all the others, the springs are too long.
Old 12-04-2020, 01:04 PM   #9
Automotive Stud
That's the answer right there, thank you!
Old 12-04-2020, 01:15 PM   #10
Tim Ayers
Thanks, Kube. Any ideas on how to fix the long spring? Cut them?
Anyone know the proper/correct length of the spring?
Old 12-04-2020, 01:19 PM   #11
Tim Ayers
Thanks for the tip, Rich.
Old 12-04-2020, 03:39 PM   #12
Kube
Kube's Avatar
I cut the springs.
