12-04-2019, 04:47 PM | #1 |
KRW shock absorber wrench
Can any body show a picture of this wrench. Measurements would also be helpful. Might there be one for sale????
12-05-2019, 02:08 AM | #2 |
Re: KRW shock absorber wrench
Don't have any info to help but here is a good place to start;
http://krwilsontools.com/
I know the voices aren't real but damn they have some good ideas! |
12-06-2019, 10:25 PM | #3 | |
Larry shepard |
12-07-2019, 09:36 AM | #4 |
Catalog pics
Wanted flathead speed equipment Thanks |
12-08-2019, 09:38 AM | #5 | |
just curious, did that long tool to remove the outside cover work for you? there is a lot written about how difficult original shocks are to open..... |
12-08-2019, 03:25 PM | #6 |
12-10-2019, 09:58 PM | #7 |
Eric,
It works ok I put a little heat in the cover before I try and take them off. I don’t like doing shocks so don’t mess with them too often. I have the Krw fixture took to hold them along with the orher wrenches. The tools definitely help. Larry |
12-10-2019, 10:19 PM | #8 |
anyone thinking of rebuilding your shocks. should get the DVD by the Diablo A`s with the late Alex Janke, Alex did a wonderful job on putting it out there so the average person can understand. it give you a whole lot of insight on rebuilding shocks. I use to heat them up with my big torch one at a time. now I do six at a time using Alex`s way.
the big problem finding good rebuild-able cores. |
12-11-2019, 09:53 PM | #9 |
The cover is best taken off with a hammer.
First you need to burn off the hardened rubber seal. You are not trying to heat the cover. Then you want to use a small ball peen hammer to to gentle taps around the shell. What your doing it hitting it just hard enough to stretch the metal a little and break it free from the base. You can then use a strap wrench to take it off. BUT You need the treads to be tight for a better seal. You just made it loose. Now you do a bunch of small heat spots around the open area of the cover. This will shrink the cover for a snug fit. When you start out (after the threads have been fully cleaned) the will be some play back and forth in the threads. As you shrink it this will go away. As always with shrinking, do some then let it come all the way down in temp and do a test fit. Repeat till snug. Now getting the big nut off holding the chamber cover is another story. I borrowed a 3/4" air impact and bought a deep socket. I have a very large heavy vice. You need something VERY firmly hold the base. Slight movement will take away the force of the impact and could make it impossible to unscrew. I am cautious in using heat in the shocks. They are precision built things and they likely use some special metal. The valve needs to be heated. The packing needs to be burned o up some to allow the valve to come out. The valve head is fragile and needs to be treated gently. |
12-11-2019, 10:54 PM | #10 |
I use a bbq grill with Kingford charcoal You cook the bone in ribeye and potatoes when done toss the shocks on. Heat them hot then let them cool will loosen up the old gals..
12-11-2019, 11:40 PM | #11 |
This bought back memories. At our old home in Detroit (1964) you will find two 1/2" holes drilled into the concrete driveway that just happen to align with the bolt holes of a Model A shock... what a coincidence
Joe B |
12-12-2019, 09:29 AM | #12 |
Ha ha ha JoeCB that’s awesome. My 5x6 set up bench wasn’t bolted to the floor and figured made with 1/2 inch steel plate with 250# anvil, 3 vices and a handful of pexto goodies would be enough weight . Nope not with out bolting it to the floor to break the old gals
