01-19-2016, 01:10 AM | #1 |
Mercury wishbones
Does anybody happen to know the dimension for 1939 or 1940 Mercury wishbones from the center of the axel to the center of the ball? I have a set of bones that this measurement is 44 1/2 " & I am trying to figure what they are from. They are identical to 37-41 Ford bones other than the legnth. They are not "stepped" as are the 42 -48 Ford & Mercury wishbones. Thank you. Bill
01-19-2016, 03:17 PM | #2 |
Re: Mercury wishbones
1941 Fords have a one-year-only wishbone that is identical in width between the perch holes as a '37-'40, but is 4-5" longer than the '37-'40 if ya stand the two up against the wall. The '41 ALSO is not "stepped" like the '42-'48s. DD
01-19-2016, 04:53 PM | #3 |
Wow! Thanks V8 for that info.
I always thought 1937-41 Ford wish bones were EXACTLY the same length. Does that mean the 41 torque tube is also a different length than the 40? |
01-19-2016, 05:14 PM | #4 | |
Have you pulled your torque tube yet? DD http://www.flatheadv8.org/fordrear.htm |
01-19-2016, 05:20 PM | #5 |
I thought I had this article saved, when I checked I only had the first page! Thanks for posting the link again.
01-19-2016, 05:21 PM | #6 |
01-20-2016, 01:12 AM | #7 |
Thanks for the responces. I always thought that 36 thru 41 ford wishbones were all the same legnth also. I guess that this set that I'm askn about are either 41 Ford or Mercury. V8coopman, Thanks for the link to that article. I printed it out & also saved it. Bill
01-20-2016, 08:31 AM | #8 |
V8: Thanks for that article. Super helpful. I haven't yet pulled my torque tube, but I did buy a torque tube seal from Bruces Rod Shop in TX. It is a very well made high quality piece.
