12-07-2017, 02:35 AM | #1 |
By by B head
So this is why I lost a little power, and had combustion gas in the radiator.
The crack wasn’t visable to my naked eye. |
12-07-2017, 08:12 AM | #2 |
Re: By by B head
Put the head on a BBQ grill, let it heat up good and hot, use an old piston ring as rod and weld it up. Leave it on the grill and cool it down slowly. V it out a bit first of course.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool." Last edited by eagle; 12-07-2017 at 08:27 AM. |
12-07-2017, 12:39 PM | #3 |
Re: By by B head
If you are running it in a Model A I would replace it with one of the aftermarket high compression Model A heads (requires new water pump) and benefit from the increased compression. If you want to stick with the Model B head I would replace it with another one.
Charlie Stephens |
12-07-2017, 12:44 PM | #4 |
Re: By by B head
A crack in that area can easily be brazed. Drill a small hole at upper end of crack to prevent crack from enlarging, grind the crack to open it a little and give more area for the brass, not clear thru. Pre-heat whole head, braze the crack including the gasket-surface, wrap the whole head with a blanket or something to retain heat for many hours while it cools, re-machine or file flat. Machining is best to insure flatness and gasket life. Should be ready to go. OR, buy a new head that is higher in compression!
12-07-2017, 03:37 PM | #5 |
Re: By by B head
