Old 01-13-2016, 09:38 AM   #1
Cockshutt Kid
Default model B rods
Good morning. I have been cleaning up parts and starting to assemble the B engine that I got a few weeks ago. It is a diamond block with forged counterweight crank. The Babbitt was done by shop unknown for previous owner. The connecting rods are babbitted and have an oil well cut in the babbit directly over the dipper, but do not have the X shaped oil grooves . Is this an omission or are there more than one school of thought on how to do this. Should I cut some grooves before assembly, or put it together as is? If I cut them is there guideline as th how deep? Thanks, appreciate the help. Jim.
Cockshutt Kid is offline   Reply With Quote
Old 01-13-2016, 11:24 AM   #2
Mark in MT
Default Re: model B rods
I like to use the Ford pattern of oil grooves, he did more in an hour than I will do in a life time. If you have an old A or B rod around, use that as a pattern to cut the grooves, I go .030 or so deep, cut using a 1/8 ball end mill in a high speed die grinder. The X grooves tie in the dipper supply to the oil reliefs at the parting line so that the whole bearing gets oiled.
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
Old 01-13-2016, 12:37 PM   #3
Cockshutt Kid
Thanks Mark. Will give it a try, and see how I make out. Jim.
Old 01-13-2016, 12:47 PM   #4
Juggler
Juggler's Avatar
One of ours - factory cut. Groove is about 20 thou (best guess)
Cheers
Juggs
Juggler is offline   Reply With Quote
Old 01-13-2016, 01:45 PM   #5
Kohnke Rebabbitting
X Grooves on a Model A same as a Model B, just to many pictures to look through.
This was one of our spun poured rods.
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 01-13-2016, 04:29 PM   #6
Cockshutt Kid
Thanks guy's. I sure appreciate the help. I will give it a try tomorrow. Jim.
