11-01-2016, 03:53 PM | #1 |
Power steering on my 34
Finally after a winter tidy up new sump gasket engine mounts etc am re installing my Power Steering set up works great anybody wanting a few pics and explanation pm your email address and I will send them through obviously only of use to those with early cars I'd say cheers.
11-02-2016, 06:06 PM | #2 |
Re: Power steering on my 34
I would like to install power steering in my 34. Would like to know how you did the instillation.
Thanks |
11-02-2016, 06:35 PM | #3 |
Can you post it up here for all to see? What type/style setup have you used?
Thanks Martin. |
11-02-2016, 11:25 PM | #4 |
Hi scooder prefer not to sadly there are a few on the Barn who take delight in nit picking put downs which causes me to Post carefully quite often not at all, happy for genuine guys to PM me have photos shortly on the way to a couple of Barners.
5windowcoupe I have trialed the set up for over 12 months now and here we have pretty strict warrant of fitness vehicle examininations every 6 months. Apart from some professional machining require pretty straight forward utilising an MR2 electric pump and new mid 60s Mustang actuator and ram what a difference so light no extra holes are drilled anywhere. Cheers. |
11-02-2016, 11:54 PM | #5 |
Trev
PM sent Also, what current draw is the MR2 pump? If you have an idea Thanks Jim |
11-03-2016, 01:08 AM | #6 |
11-03-2016, 02:07 AM | #7 |
Trevo, did you use one of those reaction type cylinder (cylinders, not ram,you know what they do) in the drag link,like an old vickers type used on bedfords.
Lawrie |
11-03-2016, 03:05 AM | #8 |
Trevo,
Sounds like the bendix type power steering? Like the sort used from early 50's up Fords and corvettes, with the controll valve on the end of the drop arm to idler arm (center link) and the ram? I'll pm you as I'm looking at doin this on my pickup. Martin. |
11-03-2016, 08:00 AM | #9 |
I think the electric PS is also very simple and inexpensive. However it requires the modification of the steering shaft. Not really sure it would fit under a 34 dash, have a friend with one under a 38 dash.
11-03-2016, 10:46 AM | #10 |
Thanks Trev received your email. FAst service. BOb
11-03-2016, 01:33 PM | #11 |
Lawrie everything is available over the counter brand new the ram or power Steering cylinder is mid 60s Mustang. We just returned from Melbourne the Motoclassica Concourse De Elegance was amazing also went to Duttons Garage and the Fox collection
11-03-2016, 03:06 PM | #12 |
Hope all those that pm me have the pics any further explanation email me happy to help those genuinely interested cheers
11-03-2016, 03:31 PM | #13 |
Some folks over on the HAMB might be interested in this too. Can you get on that forum as well, trevo?
Houston, Tranquility base here. The Eagle has landed. |
11-03-2016, 04:46 PM | #14 |
See if you can find someone local with an F100 truck manual steering installed. Drive it, it might be all you need.
Charlie Stephens |
11-03-2016, 09:39 PM | #15 |
Interesting stuff, Ted
11-04-2016, 08:53 AM | #16 |
Hi, I have a 33 that steers like truck with 2 flats. Please send information. Thank you. Cheers Art.
11-04-2016, 01:52 PM | #17 |
Art Maurice PM me with your email address and I will send you photos which will give you an idea of the set up cheers
