Old 01-12-2018, 12:17 PM   #1
19sc29
Default Parts identification help
I ended up with some parts I have two headlights which I believe are both 1932 Ford however, one has a hole on top for a turn signal and a hole for the third wire in the base. The only other difference is the rivers in the bottom, one has flat head rivers and the other has rounded head rivers.
I also have a pedal assembly which I thought was 1932 as well. The parts were all labeled as 1932.
Last edited by 19sc29; 01-12-2018 at 03:27 PM. Reason: Added pics of pedals. What year are they for?
19sc29 is offline   Reply With Quote
Old 01-12-2018, 12:20 PM   #2
cas3
Default Re: Parts identification help
headlights look like aftermarket either guide, or blc. guide are usually stamped some where
Old 01-12-2018, 12:43 PM   #3
19sc29
I’ll have to check it out. I was honking they could be aftermarket because the way the 12 volt headlight fits in. It would have been a reflector with a lens factory.
I have to take a quick pic of the pedal assembly. That’s for mechanics brakes and I know it’s a factory piece, just not certain of the year.
Old 01-12-2018, 02:12 PM   #4
deuce_roadster
deuce_roadster's Avatar
Not Ford.
Old 01-12-2018, 03:28 PM   #5
19sc29
Thanks, how about the pedals? Any idea?
Old 01-12-2018, 04:00 PM   #6
deuce lover
deuce lover's Avatar
Big truck,not pass car
Old 01-12-2018, 05:35 PM   #7
bobwellsnoveltyshop
Pedals or mount should have some numbers on them? Would help identify them.
bobwellsnoveltyshop is offline   Reply With Quote
Old 01-12-2018, 06:10 PM   #8
19sc29
I’ll have to take a look for the numbers. Thanks guys.
Old 01-12-2018, 06:13 PM   #9
DavidG
DavidG's Avatar
Not to pile on, but the lights are definitely not Ford original equipment and as deuce lover indicated, the pedals are '32, but for big trucks (they are a very early version thereof).
Old 01-12-2018, 07:37 PM   #10
19sc29
Thank you guys. Just trying to identify the parts. The pedals will probably go up for sale so someone who needs them can use them. The headlights I’ll keep for a hot rod. Thank you guys.
Old 01-12-2018, 07:51 PM   #11
aussiesteve
The Headlights are aftermarket.
They are Arrow 775 lights.Made in Mt Holly NY.
It will be stamped on the top of the headlights
aussiesteve is offline   Reply With Quote
Old 01-13-2018, 04:42 PM   #12
nickthebandit
X2 on the headlights.
nickthebandit is online now   Reply With Quote
