02-01-2017, 03:30 PM | #1 |
engine date
I am tearing down an old 8 ba I have had for along time as you are looking at the block on the port side it has 155 stamped on it also it has been bored out 125 thou. can any one tell me what the cubic inches of the block is?
Also the cam I removed after the second lobe from the front has a 6or 9 stamped on it after the forth lobe it has C9 and after the 12th lobe it has EA stamped on it. Please advise. Semper Fi |
02-01-2017, 03:53 PM | #2 |
Re: engine date
258.54 cu. in.....if it still has the 3.75 stroke crank. DD
02-01-2017, 03:58 PM | #3 |
Re: engine date
The cam is an EAB from 1952 thru 53. They were common replacement cam for the 8BA family of engines.
02-02-2017, 09:11 AM | #4 |
Re: engine date
