Old 10-25-2019, 05:27 PM   #1
Robin 47 ford pickup
Default 1947 1 ton pickup
Hi guys , don't want to be the phantom menace, but this my first attempt to show you all my 47 1 ton pickup , just need to get the brakes sorted and we are done. 5 years work as close to original as I can get. I have more pics if anyone is interested
cheers Robin
Robin 47 ford pickup is offline   Reply With Quote
Old 10-25-2019, 06:26 PM   #2
alanwoodieman
Default Re: 1947 1 ton pickup
Nice!!
Old 10-25-2019, 06:50 PM   #3
tubman
tubman's Avatar
I really like your truck. It's a 1 ton with a six cylinder? I had an older friend who drove dump trucks just after the war. He told me that when it came to choosing trucks, the senior drivers would take the 6 cylinder Fords, then the Dodges, then the V8 Fords, and last the Chevrolets.
Old 10-25-2019, 06:54 PM   #4
JSeery
JSeery's Avatar
Very nice, looking good!
Old 10-25-2019, 06:55 PM   #5
Brian
Brian's Avatar
You can be proud of your efforts! well done indeed.
Old 10-25-2019, 07:40 PM   #6
Does any one know of anybody wrecking a 47 pickup ? I need a handful of original bolts that were broken when i took this truck apart ? mainly the small bolts with star washers that held the radiator top cowl , there are 8 of these and around 3/4' long some had flanged heads . anyway if you have an unmolested truck these should still be there, the Aussie trucks used different bolts. the thing is when you pop the hood i don't want to see the wrong bolts . And does anyone have a correct front bumper or about 18" of one end , I am not happy with what I have ,so I will try to fix another one.
By the way I am open to any constructive comments about the appearance of this truck that will make it better , it came from August Kansas and I have the full history of its journey and I believe the wife of the last owner is still with us.
cheers guys ,Robin
Old 10-25-2019, 10:11 PM   #7
alanwoodieman
more pictures would be good. I have a 41 3/4 ton and a 51 3/4 ton both were/are stake beds. I made a few up grades on the 41, 51 Merc, 9" rear axle and self energizing brakes on front from a 48 up pick up
Old 10-25-2019, 10:32 PM   #8
petehoovie
petehoovie's Avatar
Robin 47 ford pickup > "this my first attempt to show you all my 47 1 ton pickup."
Old 10-25-2019, 11:08 PM   #9
mhsprecher
mhsprecher's Avatar
Beautiful. Very nice work.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 10-25-2019, 11:08 PM   #10
GB SISSON
GB SISSON's Avatar
WOW! A thing of beauty.... I have a good one ton 47 pickup and I drove it to a job today. Thankful for the great heater! I do also have 3 of them in the 'parts' stage, and a nice driver 47 one ton panel... I will look for the stuff you need tomorrow. Can you give a detailed description of bolts etc? The red one is my good one. Tomorrow being saturday I can go down to my jailbar junkyard and look!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
GB SISSON is online now   Reply With Quote
Old 10-26-2019, 07:50 AM   #11
alanwoodieman
the green one don't look bad, but the red one sure wears it's paint real good!
Old 10-27-2019, 05:37 PM   #12
GB SISSON
GB SISSON's Avatar
Well, no luck at all. Some have slotted 1/4-20s and most are a bunch of missmatched fasteners. At least 1/2 of them are sheared off. Maybe the ford bolt guy (Ray?) would be able to fix you up. Oh and here's the other truck. That previous green one gave up it's bed, rear fenders and long running boards to complete this one. The cab was really rusty, but this one from arid Eastern Washington is solid. With my fondness for the tonners, I would love to have one like that beauty you are building in Australia, but that's way out of my skill range. Tonners often had a very rough life down on the farm. Do you have a before photo?
Old 10-27-2019, 06:30 PM   #13
Sorry , I don't have any before pics I would say its about the same as the green one above ,it had a rust repair done between the cabin and tray and a right hand floor pan replaced from a leaking heater other than that just an acrylic paint job (no 2 pack paint here) and a lot of time with a hammer and dolly. The thing is the further I got pulling it apart the better it got , still had the original timbers under the cabin and the original floor in the tub .I will post some more pics soon
cheers Robin
Old 10-27-2019, 07:32 PM   #14
GB SISSON
GB SISSON's Avatar
I know the bed is the tray, but what is a 2pack? And original wood in the tub? Is the tub the floor of the tray? It must have been in very sound condition when it arrived in Aus, huh?
Old 10-27-2019, 07:37 PM   #15
alanwoodieman
2pack--base coat/ clear coat
Old 10-27-2019, 07:47 PM   #16
petehoovie
petehoovie's Avatar
Old 10-27-2019, 08:40 PM   #17
GB SISSON
GB SISSON's Avatar
OK, I get the paint thing. Acrylic is a one stage thing then. If I put anything with ANY gloss over my bodywork, it's not a pretty site. Hats off to you guys who can pull this off.
