Old 02-25-2021, 10:56 AM   #1
36coupe
36coupe's Avatar
Default Prewar heads on a 8BA
Is it possible to run pre war heads on a 8BA. I figured material would probably have to be removed above the valves.
Thanks
Regards,
Lindsay
36coupe is offline   Reply With Quote
Old 02-25-2021, 12:51 PM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Prewar heads on a 8BA
Yes, really not a big deal other than one extra water hole (on the passenger side of the block deck surface) that will need to be threaded and a plug put in.
You'll need to use 39-48 head gaskets. The water flow is a bit different - the 59AB heads were designed to take more water up through the middle water passages, while the 49-53 heads were designed to take up more water in the rear of the block. This was done to cool the rear cylinders more in the 49-53 era. Plenty of guys have put early 39-48 heads on 49-53 blocks and 49-53 heads on 39-48 blocks - so it is nothing new.
Now, if you plan to run the 49-53 timing cover and distributor, then you have to come up with a way to lock the distributor down - as it was a part of the 49-53 head. Not a big deal either - just something to note.
Old 02-25-2021, 02:04 PM   #3
19Fordy
19Fordy's Avatar
You can easily lock down the distributor by making a spacer ring that sets the distributer at it's stock height for the correct meshing with the timing gear. Then use a socket head cap screw NOT a set screw that might "fall in". Calculate the needed spacer thickness BEFORE you remove the stock head.
This 1/4 inch thick spacer was made for a Mallory dual point.
19Fordy is online now   Reply With Quote
Thread Tools
Display Modes
