Old 12-05-2020, 05:15 PM   #1
Boxcar
Default Building my own complete wood kit for 31 Coupe
The Iron Butterfly Coupe project has ventured back to an old hobbie for me...woodworking.
Taking this salvaged remnants of a kit and completely making my own kit because I'm a cheap ass.
You can keep up with build here:
https://youtu.be/6wvi2UxbWpM
Using native Fl cypress (mill is down the road from me) believe it'll be a good choice. So far, so good.
Beefed up Henry's original bow design...once 7/8's now 1" x 1 3/8ths. And I bedazzled with a routered bead along the bottom edge. I'll notch the ends after I get the main sides built. Waddya think
Boxcar is offline   Reply With Quote
Old 12-05-2020, 05:28 PM   #2
Greg Jones
Greg Jones's Avatar
Default Re: Building my own complete wood kit for 31 Coupe
I'm impressed! If you enjoy woodwork (I don't) then that is a project made in heaven for you. Keep us posted on your progress and good luck.
Greg Jones is offline   Reply With Quote
Old 12-05-2020, 05:39 PM   #3
Boxcar
Appreciate that Greg.
Old 12-05-2020, 08:40 PM   #4
Stretch Cab
Stretch Cab's Avatar
I absolutely love cypress. What have you done to be absolutely sure that it is dry? Cypress tends to want to move.
Let us live so that when we come to die, even the undertaker will be sorry. Mark Twain
Stretch Cab is offline   Reply With Quote
Old 12-06-2020, 02:22 PM   #5
Boxcar
Good point stretch... I'm at 10%.....which fits within a regional standard of 9 - 14% for this application.
Old 12-06-2020, 08:09 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Two or three things. #1, remember that when you deviate from original Ford dimensions on Rear Window Frame, Quarter Window Frame, Front Rail and Roof Rails, you affect how the upholstered trim panels will fit.
#2, please let me know how you do timewise (approximate is fine) on cutting & fabbing, -and on installation. I know how long it takes us, but I am curious how we compare to others.
#3 -can't remember the third thing I wanted to ask!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-07-2020, 07:08 AM   #7
Boxcar
I promise you there will be no comparison on the timing factor. As for panel fitment...my only deviation to date is the perforations of the top rails. My car is a Sport Coupe that will be grafted with a 5 window so not exactly a straightforward assembly process. I see significant challenges ahead with a few pieces (some like a spaghetti noodle) i don't have cnc...ill be getting by with a router table, plainer, jointer, and hand planes.
Your mention of panel fitment...any panels used would be those made by me...so not a factor.
Biggest motivation in building my own is that I have some equipment and time...and saving some $$ is nice too!
Old 12-07-2020, 08:01 AM   #8
BRENT in 10-uh-C
I am unaware of any pieces for a 45B or 50B that are 'spaghetti like'. Most are robust enough.
Looking at your list above, you should consider adding a Band Saw to your arsenal of tools which would help you tremendously. We use an old 'restored' Powermatic 143 that has been 'hot rodded' with upgraded rollers, modern urethane tires, a 1½ hp motor, and a 3 tpi blade. You can rough pieces out in a hurry and then finish them on your router table or shaper.
I'm not sure on the "saving you money" part as some will tell you that for the time you spend fabricating your own wood, you can go to work part time for McDonalds restaurant and if you work the same hours, you will have enough money to purchase a commercial kit and have money left over! The real satisfaction will be that you can boast that you did it yourself.
BRENT in 10-uh-C
Old 12-07-2020, 08:15 AM   #9
77Birdman
Nothing against any cook or fast food worker, BUT as for me, I would rather spend 10 hours in my woodshop than 5 flipping burgers!
77Birdman is offline   Reply With Quote
Old 12-07-2020, 09:09 AM   #10
McMimmcs
McMimmcs's Avatar
I think the reference to McDonalds was an analogy rather than a job specific.
McMimmcs is offline   Reply With Quote
Old 12-07-2020, 09:30 AM   #11
Boxcar
My Delta Model 20 is awaiting a set of urethane wheels and a new blade.
My reference of Spaghetti was an an analogy Brent. But to be transparent.... I get it, "you professionally build these kits" ...your level of equipment exceeds mine"...."your kits components may exceed mine"..... there you go. Think of the posts I just saved you from drafting up.
!For all...Copying this original woodkit is an exercise of the possible for me with the experience, time, and equipment of a small shop. As you contemplate your future woodkit needs and you find yourself missing one or two of the components above...you may consider contacting Brent from 10 ah C.
Old 12-07-2020, 10:11 AM   #12
BRENT in 10-uh-C
So that we are all clear, ...we don't do kits. I am excited to see your progress. Keep posting as you make progress.
BRENT in 10-uh-C
Old 12-07-2020, 10:24 AM   #13
Boxcar
#2, please let me know how you do timewise (approximate is fine) on cutting & fabbing, -and on installation. I know how long it takes us.
Ok.......stay tuned
R/
Boxcar
Old 12-07-2020, 07:22 PM   #14
McMimmcs
McMimmcs's Avatar
Every time you make a part you should make two and comprise a kit. Then sell the kit to finance other parts of your build. Wayne
Old 12-07-2020, 07:35 PM   #15
Boxcar
That's something I've been considering along the way. May be a great way to finance my builds....less time dealing with the CEO too!!!
