04-03-2015, 05:24 PM | #1 |
Modern high temp wheel bearing greese in a flathead
The rear wheel bearings in my 39 look like they were packed with a low temp grease which melted and slung oil all over the shoes and drums. Checked the bearings and they are good, just want to use a bearing grease that will not melt. What do you folks recommend and will the high temp grease for cars with disc brakes work?
Thanks |
04-03-2015, 06:38 PM | #2 |
Re: Modern high temp wheel bearing greese in a flathead
Sta-Lube has a product you get at NAPA. Someone else will chime in with the correct name for it, unless I think of it before they do.
04-03-2015, 06:46 PM | #3 |
If the grease is slinging out, I would take a look at replacing the seals.
04-03-2015, 06:55 PM | #4 |
If the rear end is overfilled with oil or the inner axle seals are bad, the gear oil can get into the bearing grease.
04-03-2015, 07:48 PM | #5 |
Rear wheel bearing grease for the old flathead needs to be a thicker stringy type grease due to the loose tolerances of this bearings rollers. Modern wheel bearing grease will not lubricate properly and has a tendency to work out of the bearing. Not sure what NAPA sells that would meet the type needed but they should be able to inform you. I'm using a Quaker State wheel bearing grease from a 2 # tub I got years ago from an antique shop petroleum product collector.
04-03-2015, 08:26 PM | #6 |
04-03-2015, 08:40 PM | #7 |
you want a long fiber wheel bearing grease, a lot of oil company's make it, just look on the can, it will say long fiber grease, the parts man should know what your asking for
04-04-2015, 10:43 AM | #8 |
WestCoast
Just about all "parts men" have retired. We now have kids, searching a computer program, for parts they have never seen. They do not know what is on the shelves, or care. I hope the dealerships are better served. Bruce
Works good Lasts long time |
04-04-2015, 02:40 PM | #9 |
40cpe: x2
04-04-2015, 03:29 PM | #10 |
Ken, very appropriate and correct advice indeed!!!
04-04-2015, 04:21 PM | #11 |
Thanks for all inputs. I went with the SL3131
