02-04-2014, 06:20 PM | #1 |
48 coupe- buggered up a wheel cylinder piston
The wheel cyls were all locked in white powder from sitting so many years. Trying to resurrect them I think I messed up the 1 inch piston on the front. Are they made to come apart like this? Can I use it?
Does anyone know if I can buy replacement pistons or am I stuck getting a whole cylinder? I have the rebuild kits. Thanks
Nothing wrong with it except for the name on the front. Alex Last edited by Bolts; 02-04-2014 at 06:31 PM. |
02-04-2014, 06:28 PM | #2 |
Re: 48 coupe- buggered up a wheel cylinder piston
when it comes to brakes go new cyl and hoses your life is worth it my2cents
02-04-2014, 07:27 PM | #3 |
Thanks oldskool. I guess my question got lost in the narrative.
Does anyone know a source for replacement wheel cylinder pistons?
Nothing wrong with it except for the name on the front. Alex Last edited by Bolts; 02-04-2014 at 09:20 PM. |
02-04-2014, 07:32 PM | #4 |
You should be able to get them off the shelf at NAPA: http://www.napaonline.com/Catalog/Re...2026066/Nao-10
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
02-04-2014, 07:38 PM | #5 | |
02-04-2014, 09:24 PM | #6 |
Nothing wrong with it except for the name on the front. Alex |
02-04-2014, 11:47 PM | #7 |
If they were full of white powder , that equals corrosion . So it would be false economy to try and save them for a few dollars. Think safety.
02-05-2014, 12:22 AM | #8 | |
The piston can be ugly as long as it's contact surfaces hold it steady in the bore and support the cup and pushrod... Karl |
02-05-2014, 01:39 PM | #9 |
For what it's worth, I discovered Joblot has wheel cylinder pistons, but not all sizes. Unfortunately they don't have the 1 inch size I'm looking for.
However, they are helpful and appear to be a good source for parts.
02-05-2014, 02:13 PM | #10 |
Wheel cylinders, especially rears at one time at least, were a big problem. The holes were drilled wrong, severely compromising the safety of the cylinder. I would buy a new pair of cylinders, carefully inspect them to make sure they are right and use them.
I will look for the thread where we discussed the problem. If the actual cylinders are good enough to clean up with a light hone, and the new cylinders are not the correct type, it may be best to build the guts of the new cylinders into the good old cylinders. That's what I had to do, but that is because I am located thousands of miles away from the suppliers and I had to make do with what was to hand. Mart. Edit: Here's a link. http://www.fordbarn.com/forum/showthread.php?t=102960 Here's the thread on the hamb. http://www.jalopyjournal.com/forum/s...d.php?t=785692 Last edited by Mart; 02-05-2014 at 02:28 PM. |
02-05-2014, 02:40 PM | #11 |
Unless you can smooth the cylinder bore out perfectly free of pits and corrosion your best bet is to just purchase a new pair of wheel cylinders. NO muss, NO fuss, no rebuild junk parts to go wrong and leak again.
dickspadaro.com |
02-05-2014, 04:43 PM | #12 |
Does anyone still sleeve them like they used to do?
02-05-2014, 07:19 PM | #13 |
I believe both White Post Restorations and Apple Hydraulics will sleeve them.
02-05-2014, 08:04 PM | #14 |
Good information. Thanks
02-05-2014, 08:43 PM | #15 |
I have n.o.s. 1" pistons.
