Old 02-05-2021, 08:47 AM   #1
77Birdman
Default Was Plywood Used
There are a few threads that pop up regarding wood questions. Purely out of curiosity, was plywood used in any parts of the original construction of any of the 'A's?
77Birdman is offline   Reply With Quote
Old 02-05-2021, 09:07 AM   #2
Ed in Maine
Default Re: Was Plywood Used
Plywood could have been used, it was invented 3500BC by the Greeks and patented in 1865 by a guy named John Mayo. I have an early set of floor boards that are made out of planks. There is a story that Ford used old shipping crates but I doubt that. Shipping crate wood is warped and cracked and was most likely used as fuel. Ed
Old 02-05-2021, 09:16 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
Plywood is original stock for front floors in 1930 & 1931 cars.
Bob Bidonde
Old 02-05-2021, 09:24 AM   #4
Jack Shaft
Jan'29 Sport Coupe,Michigan hardwood floorboards
Old 02-05-2021, 10:05 AM   #5
ronn
have never seen "original" plywood floors in any A.
only planks
Old 02-05-2021, 10:10 AM   #6
Chuck Dempsey
Chuck Dempsey's Avatar
I think my late '29 Tudor has a rear plywood floorboard. It certainly looks old enough to be original, and had anti-sqeak lining tacked around the edges.
Chuck Dempsey is offline   Reply With Quote
Old 02-05-2021, 10:19 AM   #7
jrelliott
jrelliott's Avatar
Found some in the front seat frames that was on the sides of the seats that attached to the door frame. Mine were dry rotted at the bottom and had to make new ones. Used Baltic birch plywood and sealed with poly urethane.
Old 02-05-2021, 10:24 AM   #8
Bob Bidonde
One of the front floor panels in my 1931 45B Coupe is original plywood. I am not sure of this, but I read somewhere that the original floor boards through about mid-1929 were made of tongue & groove boards from shipping cartons. In mid-1929 through 1931, the original floor board material was plywood.
Bob Bidonde
Old 02-05-2021, 11:04 AM   #9
vern hodgson
I believe I have an original plywood floorboard, will post photo later today, stay tuned.
vern hodgson is offline   Reply With Quote
Old 02-05-2021, 11:40 AM   #10
700rpm
700rpm's Avatar
The floorboards in my ‘29 Tudor are plywood. I’m the second owner, it was unrestored when I bought it, and have owned the car since 1961, so I’m pretty sure they’re original.
Weren’t the panels on woodies plywood?
Ray Horton, Portland, OR
Old 02-05-2021, 12:23 PM   #11
JayJay
At least the lower floorboard on my 30 Town Sedan, which I believe to be original, is plywood.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 02-05-2021, 02:43 PM   #12
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
The 150A/B & 225 also used plywood in the body.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-05-2021, 03:33 PM   #13
vern hodgson
This is an original
File Type: jpg 8F744900-3D9C-42C8-BDA2-6807CD3590AA.jpg (46.4 KB, 137 views)
File Type: jpg 1A5B6B41-0239-4600-87A7-992958DCDF6A.jpg (44.5 KB, 118 views)
Old 02-05-2021, 08:44 PM   #14
eagle
eagle's Avatar
I know this is somewhat out of context because it was a third party body, but I had a standrive milk truck that had plywood in some of the body construction. The plys were quite thick and as some of the glue had deteriorated so you could see it well.
Old 02-06-2021, 11:08 AM   #15
Roger V
Roger V's Avatar
Go the the Model A Judging Standards and Restoration Guidelines Area 11 page 5. Revised 2016. "In March 1929, plywood floorboards began to appear."
Roger V is offline   Reply With Quote
Old 02-08-2021, 07:51 AM   #16
77Birdman
Good info, wasnt sure there would be any response. Somewhat related I had a 1913 English made motorcycle, the floor boards in the sidecar were plywood. Common sense and logic would have made me think it was used.
Old 02-08-2021, 08:19 AM   #17
Jim M
Jim M's Avatar
I had a plywood floor in my 29 Roadster that looked VERY original. Used it for a template to replace it with birch.
Jim M is offline   Reply With Quote
Old 02-08-2021, 12:35 PM   #18
Oldford59
Hi,
I heard that Henry Ford would save and re-use wooden crate materials for fabrication of the wooden floors back in the day.
I saw it on a car show and a old school model a owner was talking about that.
Oldford59 is offline   Reply With Quote
Old 02-08-2021, 02:14 PM   #19
77Birdman
Originally Posted by Oldford59 View Post
Hi,
I have heard this many times. I know ZERO about car production, but I do know a little about wood. I would think it would be easier (thus cheaper) to have wood to be used in the production of the vehicles a known commodity and prepped accordingly. Breaking apart pallets/shipping crates, pulling nails (I doubt they used screws), then sorting into useful sized piles seems counter intuitive to me. I would think compared to the amount of wood used in the production line, 'scrap' lumber from crates would amount to very little.
Old 02-08-2021, 02:22 PM   #20
JayJay
All true, and today this would make little sense. Especially since nowadays we would just order up several hundred Conex containers of premade floorboards and have them shipped from overseas. However, consider the times when raw material cost likely made up a much higher percentage of the car's value, labor was not as comparatively expensive then as it is now. I'm sure this could be quantified but doggone if I have any numbers to do so.
JayJay
JayJay
