12-05-2020, 05:15 PM | #1 |
Building my own complete wood kit for 31 Coupe
The Iron Butterfly Coupe project has ventured back to an old hobbie for me...woodworking.
Taking this salvaged remnants of a kit and completely making my own kit because I'm a cheap ass. You can keep up with build here: https://youtu.be/6wvi2UxbWpM Using native Fl cypress (mill is down the road from me) believe it'll be a good choice. So far, so good. Beefed up Henry's original bow design...once 7/8's now 1" x 1 3/8ths. And I bedazzled with a routered bead along the bottom edge. I'll notch the ends after I get the main sides built. Waddya think Last edited by Boxcar; 12-05-2020 at 05:38 PM. |
12-05-2020, 05:28 PM | #2 |
Re: Building my own complete wood kit for 31 Coupe
I'm impressed! If you enjoy woodwork (I don't) then that is a project made in heaven for you. Keep us posted on your progress and good luck.
12-05-2020, 05:39 PM | #3 |
Appreciate that Greg.
12-05-2020, 08:40 PM | #4 |
I absolutely love cypress. What have you done to be absolutely sure that it is dry? Cypress tends to want to move.
Let us live so that when we come to die, even the undertaker will be sorry. Mark Twain Last edited by Stretch Cab; 12-06-2020 at 10:28 AM. |
12-06-2020, 02:22 PM | #5 |
Good point stretch... I'm at 10%.....which fits within a regional standard of 9 - 14% for this application.
12-06-2020, 08:09 PM | #6 |
#2, please let me know how you do timewise (approximate is fine) on cutting & fabbing, -and on installation. I know how long it takes us, but I am curious how we compare to others. #3 -can't remember the third thing I wanted to ask! |
12-07-2020, 07:08 AM | #7 |
I promise you there will be no comparison on the timing factor. As for panel fitment...my only deviation to date is the perforations of the top rails. My car is a Sport Coupe that will be grafted with a 5 window so not exactly a straightforward assembly process. I see significant challenges ahead with a few pieces (some like a spaghetti noodle) i don't have cnc...ill be getting by with a router table, plainer, jointer, and hand planes.
Your mention of panel fitment...any panels used would be those made by me...so not a factor. Biggest motivation in building my own is that I have some equipment and time...and saving some $$ is nice too! Last edited by Boxcar; 12-07-2020 at 07:14 AM. |
12-07-2020, 08:01 AM | #8 | |
Looking at your list above, you should consider adding a Band Saw to your arsenal of tools which would help you tremendously. We use an old 'restored' Powermatic 143 that has been 'hot rodded' with upgraded rollers, modern urethane tires, a 1½ hp motor, and a 3 tpi blade. You can rough pieces out in a hurry and then finish them on your router table or shaper. I'm not sure on the "saving you money" part as some will tell you that for the time you spend fabricating your own wood, you can go to work part time for McDonalds restaurant and if you work the same hours, you will have enough money to purchase a commercial kit and have money left over! The real satisfaction will be that you can boast that you did it yourself. |
12-07-2020, 08:15 AM | #9 | |
12-07-2020, 09:09 AM | #10 |
I think the reference to McDonalds was an analogy rather than a job specific.
12-07-2020, 09:30 AM | #11 |
My Delta Model 20 is awaiting a set of urethane wheels and a new blade.
My reference of Spaghetti was an an analogy Brent. But to be transparent.... I get it, "you professionally build these kits" ...your level of equipment exceeds mine"...."your kits components may exceed mine"..... there you go. Think of the posts I just saved you from drafting up. !For all...Copying this original woodkit is an exercise of the possible for me with the experience, time, and equipment of a small shop. As you contemplate your future woodkit needs and you find yourself missing one or two of the components above...you may consider contacting Brent from 10 ah C. |
12-07-2020, 10:11 AM | #12 | |
12-07-2020, 10:24 AM | #13 |
12-07-2020, 07:22 PM | #14 |
Every time you make a part you should make two and comprise a kit. Then sell the kit to finance other parts of your build. Wayne
12-07-2020, 07:35 PM | #15 |
That's something I've been considering along the way. May be a great way to finance my builds....less time dealing with the CEO too!!!
