01-10-2024, 08:55 PM | #1 |
59A Head Gaskets-ios there a left and Right Side
I've got several 59A gasket sets where only one head gasket was used. They are composite style. Is there a marking that designates left or Right side?
Thanks in advance |
01-10-2024, 08:58 PM | #2 |
Re: 59A Head Gaskets-ios there a left and Right Side
They are usually marked FRONT or have a notch on the front side.
01-10-2024, 09:03 PM | #3 |
There is a small notch cut in the edge of the gaskets. This notch goes to the front.
01-10-2024, 11:01 PM | #4 |
The notch will tell you front from back, but he is asking side to side.
I'm mainly an "8BA guy", but I don't thinks it makes much difference. Think about it; if it was important, they would be clearly marked as such. |
01-11-2024, 03:06 AM | #5 |
The heads don't have a left or right. The gaskets have a front and back. It can be confusing, especially with the copper gaskets. Because one side looks different than the other. However it's not noticeable once the heads are on.
01-11-2024, 01:54 PM | #6 |
Karl |
