Old 01-14-2021, 06:25 AM   #81
Big hammer
Default Re: Newbie '29 Speedster project, the good the bad and even the ugly (maybe)
Thanks for posting! Looking good! I would love to hear the exhaust note!
get a bigger hammer tap done
Old 01-14-2021, 08:27 AM   #82
deuce5wndw
deuce5wndw's Avatar
Outstanding Work!!
deuce5wndw is offline   Reply With Quote
Old 01-14-2021, 11:02 AM   #83
neds29
Love the dash! Great work. Creativity is #1 in my book.
Stupid question time: Are the exhaust pipes all the same length? I think that I read somewhere years ago that racers build them that way. Is that true?
Ned
Retired civil engineer.
Winters in Phoenix, summers in Ipswich, Mass. and North Dakota.
'29 closed cab pickup- Excellent AZ truck.
'29 roadster- Owned for 21 years but now sold.
'28 CC pickup- My first car in Andover, MA back in '62- '63.
neds29 is offline   Reply With Quote
Old 01-14-2021, 08:41 PM   #84
Ranchero50
Think big single cylinder lawn tractor right now. Probably be different once the blown B gets installed.
Originally Posted by deuce5wndw View Post
Outstanding Work!!
Thanks
Ned
Yes, the goal is to have the exhaust pulses exit the header primary pipe in equal impulses so I tried to keep the pipes the same length. Having too tight of a curve causes problems with the flow though. If the pulses are out of sync the pipe loses efficiency. Using the firing order 1-2-4-3 I paired 1-4 and 2-3 so the impulses will be evenly spaced out. Then both pairs go through the X crossover to feed both pairs of exhaust pipes. I wanted small pipe diameter so I had plenty of velocity which should help draw out the exhaust from the paired cylinders as the high speed exhaust pulse goes past the inactive pipe. There's a lot of science, some thermodynamics and even some math involved to get close.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 05-01-2021, 08:09 PM   #85
Ranchero50
Somewhat delayed update. Been working on the skins to finish the body. Made a tail cap, the other side panel and have been working on the shoulder skins now. Funny that it's finally getting easier to manipulate the metal. There's also a '23 Model T that showed up waiting for it's chance to become a speedster.
