Old 12-29-2023, 06:29 PM   #1
my4dv8
Default 32 commercial truck steering box
I picked up a fairly decent 32 big truck steering box . I knew it was from a big truck as it had the 4 spoke steering wheel and a much longer column drop. No problem I thought, just swap those out. It is a RHD box which is what we want. No pitman arm with it. Dang I have 8 or 9 pitman arms and an F1 arm . None are big enough to fit on the splines of the sector shaft. A miserable 0.0984 bigger at the small end of the splines. Does anyone have any knowledge on these steering boxes? Is the ratio different ? The mounting flange is different and i think the hole orientation is different, but thats ok as there are no holes in the frame on the RH side.
my4dv8 is offline   Reply With Quote
Old 12-29-2023, 07:01 PM   #2
DavidG
DavidG's Avatar
Default Re: 32 commercial truck steering box
'32 passenger car and commercial vehicle steering sector shaft diameters are the same as are the steering gear boxes. It's the big truck BB steering box assembly that's stand-alone unique.
Old 12-29-2023, 07:48 PM   #3
my4dv8
Yes this must be a BB box . Seems like 17.1 ratio. Now I need to find a Pitman arm . STD ford pitman is too small by 0.123”. Spline count is the same. It’s a very nice box.
Old 12-29-2023, 08:05 PM   #4
Tim Ayers
Fred @ Southside Obsolete should be able to help you. He is @Barnfind08 on here, HAMB and Instagram. Good luck.
Old 12-29-2023, 09:15 PM   #5
Model51
Model51's Avatar
The 1932 BB truck pitman arm is a one year only part (BB-3490-A). There was a change for the 1933-34 BB truck pitman arms (BB-3590-B) and then another for 1935-1937 (51-3590). I'm just pointing this out so that you know there are different versions of the big truck pitman arms for these years. Hope you can source a good 1932 BB pitman arm.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 12-29-2023, 11:24 PM   #6
my4dv8
Dang one year only. Would a later model big truck pitman arm with the bolt in ball work ? Just assuming it may be slightly easier to find.
Old 12-30-2023, 08:37 AM   #7
Model51
Model51's Avatar
Unfortunately I don't know the difference in shape between the 1932 and the 1933-34 styles. Perhaps the difference is the angle or length of the end of the arm? So maybe the later style would fit your '32 steering sector shaft and then you could adjust the angle or length? Sorry I can's be of more help.
Also, are you certain you have a 1932 steering box? Maybe it's a 33-34 version? I don't know how to tell these two steering boxes apart either.
Old 12-30-2023, 12:18 PM   #8
Reds34
I *think* the steering columns themselves are the same between 32-34 BB truck. David G is certainly more knowledgeable thna myself on that.
I believe the main difference between the pitman arms is where the arm is angled. I know Chris (sugarmaker) posted a side by side comparison of '32 and '34 pitmans arms.
Red
Reds34 is offline   Reply With Quote
Old 12-30-2023, 01:13 PM   #9
DavidG
DavidG's Avatar
Red,
Your right, it's the Pitman arm that differ as Chris shared with us in his thread.
Old 12-30-2023, 07:35 PM   #10
sugarmaker
sugarmaker's Avatar
my4dv8,
This is what i found. The 32 BB pitman arm is close to you in the picture, more rusty.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 12-30-2023, 07:52 PM   #11
DavidG
DavidG's Avatar
The unfortunate aspect of both those Pitman arms is that the ball is a parts of the arm, unlike the '32 passenger and commercialal arms which have replaceable ball studs.
Old 12-30-2023, 08:20 PM   #12
petehoovie
petehoovie's Avatar
Old 12-30-2023, 09:20 PM   #13
DavidG
DavidG's Avatar
Pete, Thanks once again.
Old 12-31-2023, 10:42 PM   #14
GB SISSON
GB SISSON's Avatar
Originally Posted by sugarmaker View Post
my4dv8,
Regards,
Chris and Cheryl
This is why they invented the oxy-atcetylene torch
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 01-01-2024, 02:01 AM   #15
my4dv8
I assume these are longer than a passenger arm. I am sure if the fixed ball is worn ,with some care it could be built up, or it appears that the is enough metal to make a 7degree tapered hole for a bolt in ball?
