12-23-2014, 03:02 PM | #1 |
Quartz adapter kit
I was running the old style Sealed Beam head lights...which worked great but hated they way they looked. Bought the Quartz kit from Snyders and its about half as bright as the Sealed Beam with almost no lights on low beam...got them grounded to the radiator frame. Should i run the ground to the car frame or is this normal for Quartz?
12-23-2014, 03:34 PM | #2 |
Re: Quartz adapter kit
The radiator rests on rubber shims and is not a good place for a ground. Iwould ground to the frame on clean metal. I've used the quartz kit with reflectors from Brattons and the lights are just as bright as a modern car and focus perfectly. I figure that the Snyders kit is probably the same. A 60 amp alternator was recommended with the kit that I used .
12-23-2014, 03:45 PM | #3 |
Thanks Purdy..you're right..forgot about those rubber pads under the radiator.
12-23-2014, 03:54 PM | #4 |
I've got a ground wire on both headlights that can trace their way back to the same frame bolt where the battery is grounded.
12-23-2014, 04:09 PM | #5 |
I have run headlamp ground wires down through the conduit and grounded to the frame under the nut that holds the front hood latch on both sides . That way the ground wire is completely out of sight .
12-23-2014, 04:36 PM | #6 |
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 12-26-2014 at 01:43 AM. Reason: Spelling |
12-23-2014, 04:48 PM | #7 |
12-23-2014, 04:48 PM | #8 |
Im running a 6 volt alt ..the kit is 6 volt also....
12-23-2014, 04:49 PM | #9 |
Mike...yes they make 6 volt sealed beam.
12-23-2014, 05:02 PM | #10 |
I am assuming you mean the kit where the modern light is put in behind modified reflector
The quartz kits can put out a lot of light, but it is just useless because it is not focused. A lot of light is lost blinding the oncoming traffic and the tops of the trees. Your good bet is good reflectors in a system with a good circuit. The light bulb can be an original type or better a direct replacement halogen bulb as sold by Classic and Vintage Bulbs. These bulbs can be focused. I suggest you reference the article done recently in one of the Model A club magazines where they tested the focused light intensity of the different bulbs. Unfortunately they did not test either of the direct replacement halogen bulbs currently on the market that I am aware of today. |
12-23-2014, 05:08 PM | #11 |
Yes..its a modern halogen kit with reflectors..
12-23-2014, 05:27 PM | #12 |
By connecting to the radiator, you should have a reasonable earth. Electricity will always take the easiest route and with the radiator surround, the stabilising rods at the top and the bolts through the bottom mounts there should be a good enough route.
That said, since you are running 6 volts, any voltage drop in the circuit will have a huge affect on the brightness of the lights. How were the sealed beam units connected? Did the sealed beam units use more current than the halogens? I suspect they did so a bad connection would have caused an even bigger reduction in brightness which leads me to think that your problem lies in some change you made to the connections. Would connecting the halogens the same way as the sealed beams help? (assuming they are not now)
12-23-2014, 05:39 PM | #13 |
I cant recall just how the sealed beams were connected.....the whole car was a mess of wires so i ordered a complete harness. The old sealed beams worked great but were butt ugly.
12-23-2014, 06:14 PM | #14 |
Just checking. Would not have been the first time something like that happened.
12-23-2014, 06:44 PM | #15 |
Think I'll try a different ground..that would the simplest thing to try first.
12-23-2014, 06:56 PM | #16 |
You can use your volt meter to check the ground wire for voltage drop. With the lights on if the ground circuit drops only .1 volt or less, you won't benefit from a different ground. Connect to the light ground terminal and a good ground, such as a clean head nut, then switch the meter to a low DC reading and check the voltage drop.
12-23-2014, 07:12 PM | #17 |
Thanks Tom !
12-24-2014, 01:03 AM | #18 |
I've had the quartz halogen kit installed in my A for about 8 years, and I don't get oncoming drivers blinking their lights at me, and the road in front of the car is lit up much better than my stock lights ever did. The same folks that continually run down these lights also tend to claim that somehow alternators never really work either. In our club here in S. Calif., many owners run both with great success.
12-24-2014, 03:15 PM | #19 | |
12-24-2014, 03:54 PM | #20 |
I have this same kit on my PU, and have the same results as Purdy.
Thread Tools | |
Display Modes | |
